Re: dented oil pan
[Re: IMGTX]
#3219163
03/08/24 09:09 PM
03/08/24 09:09 PM
Posts: 528 SW CO
HemiSportFury
SW CO
Most bad dents i encountered bend it at where it threads into the block. Easy place to crack the pickup there too. I've seen that too. The pickup was only hanging on by about on thread. Had to be sucking air. Was glad I didn't drive it any more than I did before checking it.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: dented oil pan
[Re: HemiSportFury]
#3219176
03/08/24 09:55 PM
03/08/24 09:55 PM
Posts: 10,730 North Dakota
6PakBee
North Dakota
I don't know about '70 but this is a direct quotation from page 9-68 of the 1967 FSM:
"The bottom of the strainer must touch the bottom of oil pan."
If '70 is similar, I'd pull that pan now.
Re: dented oil pan
[Re: 6PakBee]
#3219250
03/09/24 09:58 AM
03/09/24 09:58 AM
Posts: 6,277 nowhere
Sniper
nowhere
If '70 is similar, I'd pull that pan now. Yes, you are exactly right. Too many have no idea of that relationship. The stock, it'll say it again for the boy racers, STOCK pick up has a sheet metal shield that touches the bottom of the pan and sets the correct relationship between the pickup and pan.
