Prestolite Vacuum advance chamber #3218890
03/07/24 04:56 PM
03/07/24 04:56 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Anyone with knowledge as to what this fits?
Im fairly sure its Mopar. but no idea the application
Re: Prestolite Vacuum advance chamber [Re: gtx6970] #3218914
03/07/24 06:40 PM
03/07/24 06:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They are adjustable to a degree , spring and shims drop in to tailor opening rate and I think you can limit how much it opens , big block and small block will be different as the rotation is different , should fit a dual or single point?
Maybe ask Joesixpack , Bill Cowger , he sells a lot of that stuff.
Re: Prestolite Vacuum advance chamber [Re: JohnRR] #3219063
03/08/24 11:07 AM
03/08/24 11:07 AM
VA
dragon slayer Offline
VA
It is a dual point type. Singles are different arm. Right hand so small block and first gen hemi. What stamp # on arm, I believe should be 8. That number sets the max advance in distributor degrees the vacuum can apply.
Not the correct number for the later dual points on the 340.
Re: Prestolite Vacuum advance chamber [Re: gtx6970] #3219076
03/08/24 12:36 PM
03/08/24 12:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Prestolite Vacuum advance chamber [Re: John_Kunkel] #3219249
03/09/24 09:56 AM
03/09/24 09:56 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thought was small block.
Number on the arm is a 7
Thanks all
Re: Prestolite Vacuum advance chamber [Re: gtx6970] #3219258
03/09/24 10:35 AM
03/09/24 10:35 AM
VA
VA
Curious where that picture came from but it is wrong. That part number 2875776 is for a SINGLE point distributor 340 auto in 69. The single prestolite type can has a longer length at the hole that connects to breaker plate. DP is shorter at that bend. Also, Prestolite single point distributor vacuum can carried the IBP- part number. IAZ is a dual point number. Prestolite did make parts for the single point in MOPAR parts boxes.
67 273 dual point uses 1843034 used IAZ-2023RG
68 340 DP uses 1689765. used IAZ-2023RA
The Prestolite books do not cross the RF to those distributors. Again, the low vacuum arm #, 7 is not typical for late model Mopars.
