If converting all four wheels to disc brakes, is it still necessary to use a proportioning valve?? Thanks
If you are referring to what the OEM's used in a disc/drum set up the answer is no. Those do more than just proportion and it's those added functions that you do NOT want in an all disc setup. But if you are talking about an aftermarket adjustable type proportioning valve that only proportions then the answer is maybe. If you follow AndyF's advice, probably not, but if it is needed it would be to fine tune, not as a crutch for a cobbled together and misapplied setup.
