Page 3 of 3 1 2 3
Re: type F transmission fluid ?? [Re: moparx] #3218607
03/06/24 02:59 PM
03/06/24 02:59 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Originally Posted by moparx
thanks all. up
a couple of days ago, i ordered 24 quarts from rock auto.
with tax and shipping, along with the 5% discount coupon, it came out to $4.41 per quart.
beer
Which Brand fluid did you decide??
the cheapy, Max1.
beer
Re: type F transmission fluid ?? [Re: dvw] #3218608
03/06/24 03:01 PM
03/06/24 03:01 PM
Mo.
racerx Offline
racerx  Offline
Mo.
If your not running a trans brake. If you have a reasonably sized cooler. If your trans was assembled with correct clearance. Then any fluid will work.
Doug
Doug, what brand would you recommend for a tranny that has a break/race clutches/aluminum drums that Rock auto sells?
I currently run JR1 synthetic. But in the past I’ve run Walmart Dexron with zero issues.
Doug
Re: type F transmission fluid ?? [Re: moparx] #3219901
03/12/24 08:48 AM
03/12/24 08:48 AM
an8sec70cuda Offline
I use Type F. For the abuse my transmission has seen (4 digit HP in a nearly 2 ton car), it's been great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: type F transmission fluid ?? [Re: an8sec70cuda] #3219921
03/12/24 10:45 AM
03/12/24 10:45 AM
Richmond, Indiana
19swinger70 Online work
19swinger70  Online Work
Richmond, Indiana
I have been using Jeg's brand "quick shift". I am sure it is just Type F private labeled for Jeg's.
I get it in one gallon jugs for an ok price when I have a discount code and free shipping. My local part stores either do not have anything but synthetic, OR only stock 1 qt or 2 quarts of fluid on the shelves anymore. Who the heck only uses 1 or 2 quarts of trans fluid?
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: type F transmission fluid ?? [Re: 19swinger70] #3219940
03/12/24 11:49 AM
03/12/24 11:49 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I guess the quarts are just there for topping off. They want you to buy $$ synthetic for fill ups. Same thing for engine oil. The only conventional engine oil at the local O'Reilly's is quarts of their store brand. And forget VR1. They only ever have 20W50. I don't own a blown dragster.
Re: type F transmission fluid ?? [Re: GomangoCuda] #3219963
03/12/24 01:03 PM
03/12/24 01:03 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Don't no what this world is coming to, but it's getting difficult to find conventional 10w30-40 motor oil now days. shruggy
Re: type F transmission fluid ?? [Re: moparx] #3221353
03/19/24 05:47 AM
03/19/24 05:47 AM
Chicago-area Illinois
4mopower Offline
4mopower  Offline
Has anyone tried this product "Lucas Semi-Synthetic Automatic Transmission Fluid Sure Shift"
https://www.summitracing.com/parts/luc-10166#overview
Re: type F transmission fluid ?? [Re: 4mopower] #3221388
03/19/24 10:44 AM
03/19/24 10:44 AM
where is the best place to order transynd? EDIT & is there different types of it (which is best?).
Re: type F transmission fluid ?? [Re: RapidRobert] #3221423
03/19/24 01:00 PM
03/19/24 01:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As much as I hate to say this I just use Amazon. Has always been the least expensive place for me and we don't pay shipping. Just one Transynd 668. You can get it through Oreilly or probably any parts store as well.
Re: type F transmission fluid ?? [Re: Mopar.70] #3222035
03/22/24 02:15 AM
03/22/24 02:15 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I run B&M Trick Shift. Yes overpriced but it works well.
CrAzYMoPaRGuY
Re: type F transmission fluid ?? [Re: CrAzYMoPaRGuY] #3222037
03/22/24 05:03 AM
03/22/24 05:03 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The only one being tricked is YOU. Lol 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Page 3 of 3 1 2 3
