B-body: 426 Hemi headers w/ column auto #3218548
03/06/24 11:06 AM
03/06/24 11:06 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Looking to add TTI headers to my Superbird, 426 Hemi column auto. TTI mentions that there are issues with fitment when a vehicle is column auto, which my Superbird is. I added TTI's to my 69 Charger Daytona with a 426 Hemi, but it is console auto, so no issues......
Cheers,
Troy
Houston Mopar Connection Club
Re: B-body: 426 Hemi headers w/ column auto [Re: hemi68charger] #3218599
03/06/24 02:39 PM
03/06/24 02:39 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Here is a '70 road runner with a modified pivot bar (z bar?). In this pic it has manifolds, but it has since been switched to 2-1/8" TTI headers. We cut out the middle and welded in a bow to go up and over the exhaust. Unfortunately, the column shift linkage is a modified set from a '73 Satellite, so it may not directly translate to your factory set. (I used Schumacher mounts for the Hemi, if that makes any difference.)
Re: B-body: 426 Hemi headers w/ column auto [Re: 73DAD] #3218601
03/06/24 02:45 PM
03/06/24 02:45 PM
Houston, Tx
Houston, Tx
My Bird is a factory Hemi Bird, hence not too keen on having to get the Schumacher mounts........ This might be a daunting exercise... Thanks for the reply.
Troy
Re: B-body: 426 Hemi headers w/ column auto [Re: hemi68charger] #3218623
03/06/24 03:43 PM
03/06/24 03:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Here is what the 70 up E body and 71 -74 B body bellcrank looks like , you could get another bellcrank and modify it , cut out where it will hit the header , weld a flat bar to either side of the cut and weld the piece you cut out back in the middle out of the way of the header ?
https://www.classicindustries.com/product/all-years/dodge/challenger/parts/ml18322.html
Re: B-body: 426 Hemi headers w/ column auto [Re: hemi68charger] #3218656
03/06/24 05:42 PM
03/06/24 05:42 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You won't need Schumacher mounts for this.
2011 Drag Pak Challenger
