bs27n0 WIW #3217842
03/03/24 08:57 PM
03/03/24 08:57 PM
edison NJ
chez440 Offline OP
chez440  Offline OP
edison NJ
I'm thinking of selling my 1970 N code Cuda as I have found another car. Car has been sitting since 1982 in a garage. Previous owner blew up the 440 sitting in it. Car has minimal rust. Trunk has some pin holes, quarters minor bubbling down low, frame rails cowl fenders and doors are excellent. The top is in great shape. Optioned with PS, PDB ,Power top , Rallye gauges, A31 performance axle, has a 956 radiator. Car was FK5 with black interior but painted black in the late 70's. It has 15 ich rallye wheels and 4 speed from the factory. 1 of 68 cars made in this configuration. 18 spline trans restored, I have a 74 HP 440 short block needing build, new carpet, new Legendary seats. No build sheet or fender tag. I spoke to Dave Wise several times and had a tag made by him. Any guidance would be appreciated. Pics attached are how I found it.
Re: bs27n0 WIW [Re: chez440] #3217847
03/03/24 09:06 PM
03/03/24 09:06 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
up.....
Re: bs27n0 WIW [Re: chez440] #3217849
03/03/24 09:09 PM
03/03/24 09:09 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
It is a great starting point, and has some nice things going for it. As it sits my guess would be in the $30,000 to $40,000 range. Not many big block 4 sp convertibles where built.
Good luck with your sell and new purchase.
My Monster are real!
Living within your means makes life pretty easy.
Re: bs27n0 WIW [Re: chez440] #3217854
03/03/24 09:15 PM
03/03/24 09:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You are saying he made a tag for a car with no original documentation to go on?
Can you please elaborate?
Re: bs27n0 WIW [Re: Alaskan_TA] #3217855
03/03/24 09:22 PM
03/03/24 09:22 PM
edison NJ
chez440 Offline OP
chez440  Offline OP
edison NJ
Tag was made based off photos I provided and a document he sent me. The tag IS a reproduction as I am not trying to pass it off as original. It states in the description that it is in the upper right corner with a 70. He doesnt make original tags without build sheet. Sorry if I confused anyone as I am not trying to be misleading.
Re: bs27n0 WIW [Re: migsBIG] #3217861
03/03/24 09:53 PM
03/03/24 09:53 PM
edison NJ
chez440 Offline OP
chez440  Offline OP
edison NJ
No....original 383 long gone. A 440 was installed along with the 18 spline trans. Original drivetrain is MIA
Re: bs27n0 WIW [Re: chez440] #3217882
03/03/24 10:55 PM
03/03/24 10:55 PM
Central NC
gch Offline
gch  Offline
Central NC
Absolutely love it. If I could afford it I would have no problem cleaning it up and going through the mechanicals and driving the snot out of it.That is a time capsule and a rare one at that.
Re: bs27n0 WIW [Re: chez440] #3217971
03/04/24 11:31 AM
03/04/24 11:31 AM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
Since you don't have the original numbers tranny and no documentation is it possible the car could have come with a 3 spd manual? I assume you can see the original hump with original paint on the floor. Very cool project, numbers or not.
1970 Dodge Challenger T/A
Re: bs27n0 WIW [Re: jeff968] #3217982
03/04/24 12:01 PM
03/04/24 12:01 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
What would prompt the 3 speed question if I might ask?
quote=jeff968]
Since you don't have the original numbers tranny and no documentation is it possible the car could have come with a 3 spd manual? I assume you can see the original hump with original paint on the floor. Very cool project, numbers or not. [/quote]
STOP POTATO HATE!
Re: bs27n0 WIW [Re: Mr PotatoHead] #3218023
03/04/24 02:50 PM
03/04/24 02:50 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
Well, if you know you are looking at a BS27N0B and it is an original manual transmission car but you don't have any documentation or matching numbers tranny both the 3spd and 4spd manuals were available and it could be either? You just don't know.
Re: bs27n0 WIW [Re: jeff968] #3218046
03/04/24 03:52 PM
03/04/24 03:52 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Easiest way to tell a 4 speed from a 3 speed manual transmission Barracuda/Cuda, is the 4 speed will have a reverse dash light.
Re: bs27n0 WIW [Re: jeff968] #3218064
03/04/24 04:55 PM
03/04/24 04:55 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Thanks for the reply. Whats the known breakdown on 3 speed cars if its known?
In this case wouldnt you go by the odds on it being a 4 speed vs a semi oddball? Yea put a three speed in it and in 20 years it will be an org. three speed car, sad but true.
STOP POTATO HATE!
Re: bs27n0 WIW [Re: Mr PotatoHead] #3218075
03/04/24 05:45 PM
03/04/24 05:45 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Why are you saying it's a A31 performance axle car??? Is that just based off of a cooler still underhood with the PS pump?
From all we know here I would put it around 40K.
Thanks Ron
Re: bs27n0 WIW [Re: Mr PotatoHead] #3218090
03/04/24 06:17 PM
03/04/24 06:17 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
They only made 9 383 3spd convertibles! But on a car like this you hate to "guess". But with the documentation missing it is what it is.
Re: bs27n0 WIW [Re: jeff968] #3218091
03/04/24 06:22 PM
03/04/24 06:22 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
I would of never guessed it would be that many even. Limited on ebody info most the 3 speeds I ran across and even had one were like 73 challengers. I really didnt mind the 3 speed oddly.
That car was talked about on here maybe a year ago.. maybe by the current owner. Same pics though.
STOP POTATO HATE!
Re: bs27n0 WIW [Re: spk2go] #3218124
03/04/24 07:47 PM
03/04/24 07:47 PM
edison NJ
chez440 Offline OP
chez440  Offline OP
edison NJ
Reverse light on dash present
Re: bs27n0 WIW [Re: RJS] #3218125
03/04/24 07:48 PM
03/04/24 07:48 PM
edison NJ
chez440 Offline OP
chez440  Offline OP
edison NJ
3.91 gear verified. I dont think rear axle has ever been touched.
Re: bs27n0 WIW [Re: Alaskan_TA] #3218218
03/05/24 06:55 AM
03/05/24 06:55 AM
northwest49
feeeighteefee Offline
northwest49
no docs and a tag made? makes yah go mmmh..greed is money.... fact !
Re: bs27n0 WIW [Re: feeeighteefee] #3218239
03/05/24 10:18 AM
03/05/24 10:18 AM
California
biggE Offline
biggE  Offline
California
With the way things are today, if the car is pretty much complete and minimal rust I'd say 50k+. Try to find a decent 70 or 71 cuda or Barracuda convertible, good luck. Pricing on restomods is 150-200k. A decent real 70 cuda convertible 340 or 383 are priced over 100 to 160k. The newer group of buyers is not as concerned with numbers as the group most of us are probably in. A lot of them are just looking for a good project to build something they want.
Re: bs27n0 WIW [Re: jeff968] #3218250
03/05/24 10:55 AM
03/05/24 10:55 AM
Kirkland, Washington
Pacnorthcuda Offline
I am thinking 50k too, for the same reasons. There are enough deep pockets out there looking for a high dollar restomod project that don’t give a damn about documentation. This is a great vert project.
