Re: 74 duster starter stays engaged
[Re: chargers777]
#3218244
03/05/24 10:29 AM
03/05/24 10:29 AM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
If I pull the yellow ignition wire off the starter relay it will still start with the key. If I leave the yellow wire hooked up to the relay the starter stays engaged. Is this a bad starter relay or is something wired wrong? Just got the car and can tell someone has been in the wiring. Yellow should only be hot when the key is in the crank position. If it is cranking all the time you either got a bad switch or the yellow is possibly melted into a 12 volt hot source.
[Re: jlatessa]
#3218257
03/05/24 11:20 AM
03/05/24 11:20 AM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
Couldn't the relay be at fault?
Joe Yes it could be, but the factory yellow wire is from the ignition switch. The op said disconnect the yellow wire and it works normal when it shouldn't work at all. This leads me to believe the wiring is wrong or the relay has some connection issue. That is why I specified checking voltage at the wires and if the signal there was the correct polarity. These old cars will burn the wiring harness and cross wires in a heartbeat.
[Re: B1MAXX]
#3218575
03/06/24 01:12 PM
03/06/24 01:12 PM
Posts: 13,604 md
mopars4ever
md
1974's had seat belt interlock, that could be what the box is.
Something is keeping the relay picked, test the voltage on the yellow while operating the ign. sw.
Pretty sure the seat belt interlock has a red button to push.
