Re: Pitman arm install [Re: 6PAX] #3217655
03/03/24 10:00 AM
03/03/24 10:00 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by 6PAX
The original arm fit fine but it was the 69 style arm, not the 73-later type I bought to match the 73-later steering linkage I am using.
Curiosity question; why did you go to the 1973-later type rather than stay with the stock 1969? I have a 1969 GTS and am wondering what the advantage is of the later setup.
Re: Pitman arm install [Re: 6PakBee] #3217657
03/03/24 10:11 AM
03/03/24 10:11 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Must be a design mis-match somewhere between the two.
Re: Pitman arm install [Re: 6PakBee] #3217937
03/04/24 09:11 AM
03/04/24 09:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He changed the centerlink to the 73/up unit because I think he was having an issue with the pitman arm being close to header tubes and the centerlink hitting the pan ... the stud points down instead of up so you have to use the 73 up idler also .
Here is the thread ...
centerlink issue
Re: Pitman arm install [Re: JohnRR] #3217959
03/04/24 10:39 AM
03/04/24 10:39 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks, that makes it much clearer.
Re: Pitman arm install [Re: JohnRR] #3217978
03/04/24 11:51 AM
03/04/24 11:51 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Yes, that was the reason.
I called Mevotech today and they won't do anything about it. All the woman would say is she agreed there is a problem with the arm but she doesn't know what. I said, there is only one thing it can be, obviously the i.d. of the splines is undersized but she made no offer of rectifying the situation. So, I'm going to have to eat the $40 I paid for it and get another arm.
Re: Pitman arm install [Re: 6PAX] #3217999
03/04/24 01:49 PM
03/04/24 01:49 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
did you measure the distance from each end of the steering link to the floor, presuming the floor and the car are level? Steering linkage is suppose to be a moving parallelogram
this is the real test to see if it is on far enough
Before assy on the car did you dress burrs off the mating surfaces?
Did you lubricate the splines?
Re: Pitman arm install [Re: 6PAX] #3218000
03/04/24 01:51 PM
03/04/24 01:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Who did you buy it from ?
I'm surprised you got that attitude , When I called their customer service line , granted a year and a half ago , the guy I talked to was very helpful.
Re: Pitman arm install [Re: JohnRR] #3218029
03/04/24 03:07 PM
03/04/24 03:07 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
"did you measure the distance from each end of the steering link to the floor, presuming the floor and the car are level? Steering linkage is suppose to be a moving parallelogram
Yes, yes and yes.
"Who did you buy it from ?"
I bought it on Amazon. The vendor name was USAutopartsCar.
Re: Pitman arm install [Re: 6PAX] #3218037
03/04/24 03:36 PM
03/04/24 03:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Have you tried the prussian blue of machinist' dye suggested earlier? the taper of the splines may be the issue.
if you still have the old one, measure the thickness, and ID of the splines at the large and small ends and compare it to the new one. A local machinst may be able to hel you with the dimensions if needed
Might also just try a different brand from a local parts store. take your old one with you for comparison or look for an NOS one beer
Re: Pitman arm install [Re: TJP] #3218066
03/04/24 05:02 PM
03/04/24 05:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
kinda what I was thinking but I was wondering if the taper of the shaft is different between the years and not the arm itself? Trying another arm should answer that.
Re: Pitman arm install [Re: 6PAX] #3218243
03/05/24 10:29 AM
03/05/24 10:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
going to guess it's way past returning it ?
Re: Pitman arm install [Re: JohnRR] #3218286
03/05/24 12:44 PM
03/05/24 12:44 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Yes, the return period from Amazon closed in mid January.
Re: Pitman arm install [Re: 6PAX] #3218481
03/05/24 10:15 PM
03/05/24 10:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'd do the Prussian blue check and then start some careful filing on the contact area of the pitman arm splines. With that taper, a little bit will gain you a lot.
Re: Pitman arm install [Re: 6PakBee] #3218522
03/06/24 08:51 AM
03/06/24 08:51 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Still think this is way over thinking this.
1/2 inch of spline engagement, seems about right to me. The splines can't come through and the total thickness is what 3/4?
Re: Pitman arm install [Re: B1MAXX] #3218745
03/06/24 10:17 PM
03/06/24 10:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I was just wondering this as I was reading. So, How thick is the pitman arm? beer
