type F transmission fluid ??
#3217471
03/02/24 01:53 PM
03/02/24 01:53 PM
Posts: 19,408 north of coder
moparx
around here, there doesn't seem to be a source for type F fluid, not even at the two local wally worlds. on line, it seems that stuff goes for $7.00-9.00 per quart. so what is the go to stuff these days ? hydraulic fluid or ???? i really don't want to use type 4 or generic/universal ATF.
Re: type F transmission fluid ??
[Re: rickraw]
#3217492
03/02/24 02:45 PM
03/02/24 02:45 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
I have switched to Transynd fluid in all my stuff. BEen running it for a couple of years and still looks new. It is the Allison trans fluid used in Medium trucks, motohomes etc.
[Re: racerx]
#3217525
03/02/24 05:38 PM
03/02/24 05:38 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Rural king had a lot of it last time I was there.
[Re: Al_Alguire]
#3217526
03/02/24 05:39 PM
03/02/24 05:39 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
I have switched to Transynd fluid in all my stuff. BEen running it for a couple of years and still looks new. It is the Allison trans fluid used in Medium trucks, motohomes etc. Application Castrol TranSynd can be recommended for all vehicles calling for Dexron III/Mercon or Allison TES 295 and TES 468 ATF's suitable for bus and refuse vehicles with automatic transmissions. Garbage trucks? That TranSynd is about $50 /gal. Almost triple the cost of Dexron III/Mercon that it replaces. Does it say B&M Trick Shift on it?
[Re: GomangoCuda]
#3217529
03/02/24 05:51 PM
03/02/24 05:51 PM
Posts: 4,981 new jersey usa
11secdart
new jersey usa
Advance has it ( by me anyhow ) $9.79 a quart in stock , I just bought some a few weeks ago.. they had to order it for me last time as they didn't stock it .
[Re: Al_Alguire]
#3217536
03/02/24 06:18 PM
03/02/24 06:18 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
I have switched to Transynd fluid in all my stuff. BEen running it for a couple of years and still looks new. It is the Allison trans fluid used in Medium trucks, motohomes etc. It’s also used in class 8 big rigs, I bought many thousands of gallons during my time building Kenworths.
[Re: Uberpube]
#3217576
03/02/24 09:00 PM
03/02/24 09:00 PM
Posts: 11,712 Portage,michigan
B3422W5
Portage,michigan
O Reilly’s always have it around here. Never had an issue getting it other places either.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Al_Alguire]
#3217580
03/02/24 09:11 PM
03/02/24 09:11 PM
Posts: 16,482 On the run…
BloFish
On the run…
I have switched to Transynd fluid in all my stuff. BEen running it for a couple of years and still looks new. It is the Allison trans fluid used in Medium trucks, motohomes etc. That’s all I use.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3217639
03/03/24 09:10 AM
03/03/24 09:10 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I use the Walmart brand type F. The store usually has some in stock if not I order it from Walmart online and have it delivered.
68 Barracuda Formula S 340
[Re: Al_Alguire]
#3217646
03/03/24 09:35 AM
03/03/24 09:35 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I have switched to Transynd fluid in all my stuff. BEen running it for a couple of years and still looks new. It is the Allison trans fluid used in Medium trucks, motohomes etc. Ditto, That stuff is worth every penny.
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3217697
03/03/24 12:18 PM
03/03/24 12:18 PM
Posts: 2,506 PA
moparacer
PA
You all can take it for what it is worth, but I moved away from Type F when it started getting scarce and expensive in my Glide and went to the Valvoline universal full synthetic you can buy at any Walmart for $20-25 a gallon.
2860 lbs 800+ hp and beat for 3 years at 200 passes a year, and when I pull the trans apart to look it over this week I will reuse the band and clutches. Which are a lot older than that.
Works great in my old Duster with a 904 in it too.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: sr4440]
#3217700
03/03/24 12:23 PM
03/03/24 12:23 PM
moparx
thanks fellows ! i never thought about rock auto. i'll have to check wally world on line and see about that as well. i was thinking about using a type of hydraulic fluid, but i didn't get that far. looks like i have homework to do..........
[Re: Bad340fish]
#3217713
03/03/24 01:04 PM
03/03/24 01:04 PM
Posts: 4,679 Wichita
GY3
Wichita
I use the Walmart brand type F. The store usually has some in stock if not I order it from Walmart online and have it delivered. I was just getting ready post this.
[Re: GY3]
#3217726
03/03/24 02:01 PM
03/03/24 02:01 PM
Posts: 2,506 PA
moparacer
PA
My Wally world and parts stores in my area always seem to keep a few quarts of F on hand and everytime I had to run all over creation gathering up enough.
[Re: moparacer]
#3217765
03/03/24 03:57 PM
03/03/24 03:57 PM
Al_Alguire
Las Vegas
If you are stuck on Type F Walmart generall always has it.
As for the Transynd it keeps my stuff much cooler than anything else I have ever used. And if you run a car on a stop they tend to put some heat in the trans. If oyu want to run B&M colored type F go for it. Ill stick with what has worked best for me. And I have been through a lot of cars and combos over the years.
[Re: Al_Alguire]
#3217802
03/03/24 06:15 PM
03/03/24 06:15 PM
GomangoCuda
When I mentioned the B&M blue Stuff i was being sarcastic. Guess I should have put a smiley on there. Nobody I know has used that snake oil for about 50 years. If the TranSynd runs significantly cooler then that would be worth paying for. Does it affect stall speed, et or consistency?
[Re: GomangoCuda]
#3217879
03/03/24 10:45 PM
03/03/24 10:45 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Type F
$4.49 at my local Fleet Farm
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
