Re: type F transmission fluid ??
[Re: moparx]
#3218607
03/06/24 02:59 PM
03/06/24 02:59 PM
Posts: 4,066 Mo.
racerx
Mo.
thanks all. a couple of days ago, i ordered 24 quarts from rock auto. with tax and shipping, along with the 5% discount coupon, it came out to $4.41 per quart. Which Brand fluid did you decide?? the cheapy, Max1.
[Re: dvw]
#3218608
03/06/24 03:01 PM
03/06/24 03:01 PM
Posts: 4,066 Mo.
racerx
Mo.
If your not running a trans brake. If you have a reasonably sized cooler. If your trans was assembled with correct clearance. Then any fluid will work. Doug Doug, what brand would you recommend for a tranny that has a break/race clutches/aluminum drums that Rock auto sells? I currently run JR1 synthetic. But in the past I’ve run Walmart Dexron with zero issues. Doug
[Re: moparx]
#3219901
03/12/24 08:48 AM
03/12/24 08:48 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I use Type F. For the abuse my transmission has seen (4 digit HP in a nearly 2 ton car), it's been great.
[Re: an8sec70cuda]
#3219921
03/12/24 10:45 AM
03/12/24 10:45 AM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
I have been using Jeg's brand "quick shift". I am sure it is just Type F private labeled for Jeg's. I get it in one gallon jugs for an ok price when I have a discount code and free shipping. My local part stores either do not have anything but synthetic, OR only stock 1 qt or 2 quarts of fluid on the shelves anymore. Who the heck only uses 1 or 2 quarts of trans fluid?
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: 19swinger70]
#3219940
03/12/24 11:49 AM
03/12/24 11:49 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
I have been using Jeg's brand "quick shift". I am sure it is just Type F private labeled for Jeg's. I get it in one gallon jugs for an ok price when I have a discount code and free shipping. My local part stores either do not have anything but synthetic, OR only stock 1 qt or 2 quarts of fluid on the shelves anymore. Who the heck only uses 1 or 2 quarts of trans fluid? I guess the quarts are just there for topping off. They want you to buy $$ synthetic for fill ups. Same thing for engine oil. The only conventional engine oil at the local O'Reilly's is quarts of their store brand. And forget VR1. They only ever have 20W50. I don't own a blown dragster.
[Re: 4mopower]
#3221388
03/19/24 10:44 AM
03/19/24 10:44 AM
RapidRobert
where is the best place to order transynd? EDIT & is there different types of it (which is best?).
[Re: RapidRobert]
#3221423
03/19/24 01:00 PM
03/19/24 01:00 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
where is the best place to order transynd? EDIT & is there different types of it (which is best?). As much as I hate to say this I just use Amazon. Has always been the least expensive place for me and we don't pay shipping. Just one Transynd 668. You can get it through Oreilly or probably any parts store as well.
[Re: Mopar.70]
#3222035
03/22/24 02:15 AM
03/22/24 02:15 AM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
I run B&M Trick Shift. Yes overpriced but it works well.
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#3222037
03/22/24 05:03 AM
03/22/24 05:03 AM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I run B&M Trick Shift. Yes overpriced but it works well. The only one being tricked is YOU. Lol 😂
