Effect on converter stall speed #3217221
03/01/24 10:12 AM
03/01/24 10:12 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Putting together a budget street car combo, and cam grinder suggested a at minimum at 2500+ stall converter (230/236 at .050 duration). I've found a local guy selling a very nice used dynamic 9.5" converter that stalled at 3800rpm behind his 340 with a 509 purple cam, 10.5:1 compression, and 4.56 gears in a street duster. My combo is a 3700lb volare wagon with an aluminum headed 8.5:1 360 running a 3.06 rear axle ratio (may go to 3.23 at some point). I have read that the lower numerical gear ratio will make the converter flash higher, but I wonder if the weight, lower compression and power will drop the converter stall speed to something more usable like a 3000-3200rpm flash point.
Looking for some input on this one since the combo will need a converter as I currently only have the stock 1800-1900 stall converter for it. Wondering if even a factory high stall (if I can find one) would be a better option, but I am trying to keep this on a budget (I know, the problem for everyone these days).
Thanks!
Re: Effect on converter stall speed [Re: mshred] #3217226
03/01/24 10:37 AM
03/01/24 10:37 AM
BDW Offline
BDW  Offline
I used this to calculate mine
More HP/torque will increase stall speed
Heavier the vehicle, the higher it will push the stall
Lower gears, such as a 2.73 or 3.08 gear, will increases stall
The mathematical constant that defines a converter's stall speed (in rpm) is called the "K" factor
K is the observed stall speed of the converter divided by the square root of the applied torque
The relationship is expressed mathematically: K = RPM/torque^0.5
Once the K factor for a converter is determined, the stall can be predicted for different torque values
Re: Effect on converter stall speed [Re: BDW] #3217228
03/01/24 10:57 AM
03/01/24 10:57 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
The lower torque you are making than the other guy will help lower the stall.
BUT
You are considerably heavier than the other guy with a considerably higher gear. This will raise the stall, likely more than your lack of torque will offset.
Pass on that used convertor.
Something like a TurboAction 17805M would probably be a better bet.
Re: Effect on converter stall speed [Re: mshred] #3217260
03/01/24 12:59 PM
03/01/24 12:59 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Don't know if this is any help but changing from a 4.10 to a 3.73 rear gear increased stall by 1000rpm on our combo.
Re: Effect on converter stall speed [Re: Tig] #3217294
03/01/24 03:08 PM
03/01/24 03:08 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Helpful info guys, thank you! I will pass on this one then. And just for future, at least I now know that the more weight and lower numerical gear ratio will INCREASE stall speed.
Re: Effect on converter stall speed [Re: Tig] #3221619
03/20/24 10:08 AM
03/20/24 10:08 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
But that is somewhat artificial. The definition of flash is the highest rpm seen before the car moves. The car moves sooner/easier with the 4:10 than with the 3.73. That earlier movement might be more beneficial that then increase in flash rpm. Did the car improve in the 60’? Always trying to understand more about the converter smile
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Effect on converter stall speed [Re: FurryStump] #3221628
03/20/24 10:45 AM
03/20/24 10:45 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
fluid can tighten or loosen the converter, Straight tractor fluid to straight dexron or a mix of them can move the stall a few hundred rpm.
IF this is a "street" race or no prep type deal, looser is usually better....just saying
....BAD A$$ STREET CAR.....
Re: Effect on converter stall speed [Re: n20mstr] #3221631
03/20/24 11:02 AM
03/20/24 11:02 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Depends, I flash to 3500 rpm because that is all my 6” tire can hold. The rest of the combo wants 5000+ flash. Some in the FAST use a programmable box to pull timing. Not there yet. My SLR is pretty low with 4:10 and a low 1st gear 904. Lets me tolerate a small bit of wheel speed before I need to pedal.
Re: Effect on converter stall speed [Re: FurryStump] #3221699
03/20/24 04:20 PM
03/20/24 04:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A 230@.050 cam is a lot of duration for a heavy car with a 8.5-1 360 and a
3.08 axle. Been there, you will not like it. Not a happy combo on the street
Doug
Re: Effect on converter stall speed [Re: FurryStump] #3221756
03/20/24 07:54 PM
03/20/24 07:54 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
No, 60ft dropped a 10th. Slower by 2 10ths, Mph dropped 4 - 6 mph while rpm remained roughly the same through the traps. Slip increased from 10 to 17 %. I have since fitted another converter but no track time as yet.
Re: Effect on converter stall speed [Re: n20mstr] #3221865
03/21/24 10:40 AM
03/21/24 10:40 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Its just a street car that I am trying to NOT turn into a full blown race car lol. It may get nitrous or a blower in the future though...
I can't remember, but what I recall the tractor fluid, like hygard, tightens by a couple hundred rpm, right?
Re: Effect on converter stall speed [Re: dvw] #3221866
03/21/24 10:42 AM
03/21/24 10:42 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Doug
Honestly, I thought that too, but this is what was recommended by the cam grinder, even giving all of the information on the combo. They also recommended an even larger grind, but I chose the smaller of the 2.
That said, something like this, would you say would like more or less converter? I am back and forth between this converter I mentioned in my original post, or a factory high stall 340 converter. Other then what I have already noted, the car MAY get a set of 3.55 gears in the future, but I know it will hurt the driveability on the highway, so that is slightly up in the air.
Re: Effect on converter stall speed [Re: mshred] #3222032
03/22/24 01:46 AM
03/22/24 01:46 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I'm wondering the same.
I just picked up a 360/380hp crate engine. 3400 pound car, 3.23 gears, 27" tall tires and a 904 based lockup. 230 ish duration at .050 I think
1 3/4" Super Comps, 650 AVS2, and an irresponsible driver.
I drive mostly highway, I like to drive at a brisk pace, but should I change the converter? It's a lockup trans and probably not a lot of options...? Factory 318 4 barrel engine in it now. 155hp?
I could swap cams in the 360/380 if necessary but I would rather not!!!
CrAzYMoPaRGuY
Re: Effect on converter stall speed [Re: Tig] #3222068
03/22/24 09:54 AM
03/22/24 09:54 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Sounds like the converter definitely not happy. I know people who have tried increasing slip % at the top to try and increase torque multiplication down track, but no real results yet. 10% seems a bit high. I’m at 4-5 % at the stripe. Which car?
Re: Effect on converter stall speed [Re: mshred] #3222072
03/22/24 10:16 AM
03/22/24 10:16 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
ATI makes 20w and 30w type f transmission fluid. Going from the 20w to the 30w affected mine about 200 rpm
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: Effect on converter stall speed [Re: tvt59] #3222085
03/22/24 10:55 AM
03/22/24 10:55 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Runing a low gear like the 3.08 doesnt allow the rpm to get high enough to couple. We ran Dizusters turbo car with a 2.76 gear. It ran 10.50's but the slip was as I recall was over 25%. Why? The car wasn't done accelerating. My street car ran a 5300 with a 3.55. Slipped like mad. Felt like it had a V V T trans. Same converter with a 4.30 it drives great on the street. Cam, converter, gear all have to be in sync to drive nice.
Doug
Re: Effect on converter stall speed [Re: FurryStump] #3222087
03/22/24 11:21 AM
03/22/24 11:21 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
8" ATi converter, it was originally specified for a 750 ish HP 528motor. It worked ok with the 572/580 motor and and 4:10 rear, showed over 900hp on a good day at the track going off the numbers and the weight (4023lb). Stall was originally 5200 (4:10) and it would go to 6000+ with the 3.73 gear. Data showed around 9 - 10% slip (4:10) which I was OK with as the car worked ok. I guess the change in rear ratio pushed the converter too far grin
We have fitted an ATi converter (9 1/2") that was built for our 655ci motor with 1000+ hp and a 4:10 rear, hopefully that will improve things.
Re: Effect on converter stall speed [Re: dvw] #3222090
03/22/24 11:34 AM
03/22/24 11:34 AM
gregsdart Offline
gregsdart  Offline
Doug
i agree.it will really hurt torque. A cam like a Comp 268h would be ideal,,,,,
Re: Effect on converter stall speed [Re: tvt59] #3222093
03/22/24 11:46 AM
03/22/24 11:46 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Stalled higher or lower with the switch?
Re: Effect on converter stall speed [Re: dvw] #3222094
03/22/24 11:47 AM
03/22/24 11:47 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Doug
So in this case, would the 2500 stall or the 4000 stall be ideal? Cam company said 2500+ stall for converter giving them all the combo details. Maybe the lower stall would work better as to couple sooner?
