Small Block Camshaft Recommendation #3215959
02/24/24 11:49 PM
02/24/24 11:49 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Looking for feedback from the forum on camshaft type/brand for a 340.
I’ve heard lately hydraulic flat tappet cams had some issues due to a lifter manufacturing issue. Not sure if that is the sole issue, but I’ve heard techs have replaced multiple canes are wiped out.
There is also a lot of discussion around an insufficient amount of ZDDP being added to oil causing cam issues.
For some, remember no car shows/racing, so we have to talk about something.
Back to the question…
A friend is in the process of replacing his 340 cam in a 70 Barracuda Convertible (NNM).
He wants a cam that is good for street use only. Below are the cam spec's for the one currently installed in the engine assembly. (wiped out cam - very low mileage and ZDDP usage). In summary a lifter failed and mushroomed causing damage to cam/engine system.
He would prefer to migrate to a hydraulic roller cam over the flat tappet. He wants something that performs similar to a stock 340 cam, but thought the current cam was bit too lumpy for his preference.
Any cam recommendations (type/brand/spec)?
Thank you in advance for your feedback.
Re: Small Block Camshaft Recommendation [Re: vinnyd76] #3215961
02/25/24 12:13 AM
02/25/24 12:13 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
What's actual comp. ratio?
Re: Small Block Camshaft Recommendation [Re: PhillyRag] #3215988
02/25/24 08:01 AM
02/25/24 08:01 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Compression = 9.86:1
Re: Small Block Camshaft Recommendation [Re: vinnyd76] #3215998
02/25/24 09:38 AM
02/25/24 09:38 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
210-214 at .050 intake on a 110 lobe sep. for a little chop.
I don't think all manufactures are having cams go flat.
just my 2 cents.
Re: Small Block Camshaft Recommendation [Re: vinnyd76] #3216002
02/25/24 10:22 AM
02/25/24 10:22 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I think the second smallest Crane street roller would do what he wants it to do if it was still available, but it isn't.
https://www.summitracing.com/parts/crn-699611#overview
But in a nutshell I'd try taking about 10 degrees @ .050 from where you're currently at, and would have it ground on a 112 or possibly even 114 to make it as smooth as he seems to want.
Want to hit the "easy" button?
Call Porter racing heads at (802) 951-1955 and order up a custom grind.
Ask Dwayne to pick it out and give him a credit card number, he'll have it drop shipped from the cam manufacturer.
Rich H.
Esse Quam Videri
Re: Small Block Camshaft Recommendation [Re: ZIPPY] #3216069
02/25/24 02:13 PM
02/25/24 02:13 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
These days I would not consider a flat tappet cam in anything unless that was the only option.
Re: Small Block Camshaft Recommendation [Re: 340Cuda] #3216212
02/25/24 11:14 PM
02/25/24 11:14 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
it is an expensive roll of the dice twocents beer
Re: Small Block Camshaft Recommendation [Re: vinnyd76] #3216229
02/26/24 12:13 AM
02/26/24 12:13 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
crane 272 h m v would be perfect
216 @ 50 112 lobe sep
i use amzoil 30 w brake in oil for first 1200 miles !
thev valvoline V R 1 - 10 / 30 RACE OIL
NO cam falures ever !
1800 to 3800 rpm brake in 20 min 900 rpm idle min also after brake in .
if you have to add additives to your oil you have the wrong oil !
Re: Small Block Camshaft Recommendation [Re: calrobb2000] #3216283
02/26/24 10:42 AM
02/26/24 10:42 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run this Crane Hyd roller HR-222/339-2S-12 IG in my Challenger. 9.0-1 comp (runs on 87 octane), 360, 4 speed, 3.55, 27" tire. Excellent power and driveabilty with good idle quality. LD 340 intake, 650 Holley, TT I headers and TTI 2 1/2" system, ported later 360 heads. It has been 12.79@109 with full exhaust and air cleaner in place using drag radial.
Doug
Re: Small Block Camshaft Recommendation [Re: vinnyd76] #3217098
02/29/24 04:53 PM
02/29/24 04:53 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Last time I looked at roller retrofitting a 340 it was a significant expense.
Enough of an expense that a factory roller 360 Magnum starts to look like a better route.
Mo' Farts
Moderated by "tbagger".
Re: Small Block Camshaft Recommendation [Re: Grizzly] #3217169
02/29/24 11:11 PM
02/29/24 11:11 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I would 2nd that recommendation especially in light of the owner's feeling that the current cam is already a tad too hot, which I think is actually a pretty docile street cam, especially with that CR.
Either way, a move to a wider LSA would probably help here, 112 at least.
Re: Small Block Camshaft Recommendation [Re: Diplomat360] #3219900
03/12/24 08:42 AM
03/12/24 08:42 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
on a flat tappet, I would have Bullet Grind you the old Ultradyne H3/H5 which is 217/221 @ .050" I would cut it on 109 and put it in at 105 ICL
It'll idle with the right 340 chop but be super responsive and have broad torque.
I don't like the Comp XE's on Mopars, I think they were designed for chevy's and the heavier mopar valvetrain just makes them really noisy. IMO
For HRs you can take ~10-12 of degrees off the .050 of a comparable FT and easily make the same or more power with better idle quality.
One issue with HR's on small mopars is the 59 degree lifter bank combined with a long HR lifter makes the "less than ideal pushrod geometry a bit worse. Solid roller bodys (except Morels that seem to use the same long body the HR's use) are generally shorter and lighter and I actually prefer SR's on smallblocks.
WIZE
In Car:
