Re: 2019 Charger
[Re: stumpy]
#3216940
02/28/24 11:36 PM
02/28/24 11:36 PM
Posts: 3,459 Dandridge TN
Dabee
Dandridge TN
I’m converting my 64 Dart to 5 x 4.5 and was considering using a late model factory rim.
Re: 2019 Charger
[Re: Dabee]
#3217461
03/02/24 01:41 PM
03/02/24 01:41 PM
Posts: 25,977 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Is the wheel bolt pattern on the new charger 5 x 4.5 ? No. The new bolt circle is 115 mm which is 4.528"
Re: 2019 Charger
[Re: Andrewh]
#3217845
03/03/24 09:00 PM
03/03/24 09:00 PM
Posts: 10,163 A Red State
SNK-EYZ
A Red State
apparently the 2014 era of chargers were 4.5 or 114.3 but I haven't tried one to confirm it. not sure if the center registry is big enough either. there apparently are a lot of newer cars that use the bolt pattern, but not much have the larger center registry hole. found some tacoma rims that would work apparently, but never pulled the trigger. had the correct off set too. That is WRONG, they are NOT 4.5 inch or 114.3 mm. They are 115 mm which is different. All 2005 on Dodge Magnum and Chrysler 300's, 2006 on Dodge Chargers and 2008 on Challengers are the 115 mm bolt circle. Putting the 5 on 4.5 inch (114.3 mm) bolt pattern wheels puts a side load on the wheel studs that they weren't designed for. The tapered seat lug nuts will be forced out of proper centering.
Re: 2019 Charger
[Re: SNK-EYZ]
#3218775
03/07/24 12:54 AM
03/07/24 12:54 AM
Dabee
Dandridge TN
apparently the 2014 era of chargers were 4.5 or 114.3 but I haven't tried one to confirm it. not sure if the center registry is big enough either. there apparently are a lot of newer cars that use the bolt pattern, but not much have the larger center registry hole. found some tacoma rims that would work apparently, but never pulled the trigger. had the correct off set too. That is WRONG, they are NOT 4.5 inch or 114.3 mm. They are 115 mm which is different. All 2005 on Dodge Magnum and Chrysler 300's, 2006 on Dodge Chargers and 2008 on Challengers are the 115 mm bolt circle. Putting the 5 on 4.5 inch (114.3 mm) bolt pattern wheels puts a side load on the wheel studs that they weren't designed for. The tapered seat lug nuts will be forced out of proper centering. Thanks that is what I was looking for. Did some research after posting this and found the new rims are 5 x 4.52 so the side load on the studs makes sense.
Re: 2019 Charger
[Re: SNK-EYZ]
#3218794
03/07/24 09:10 AM
03/07/24 09:10 AM
Posts: 6,322 nowhere
Sniper
nowhere
apparently the 2014 era of chargers were 4.5 or 114.3 but I haven't tried one to confirm it. not sure if the center registry is big enough either. there apparently are a lot of newer cars that use the bolt pattern, but not much have the larger center registry hole. found some tacoma rims that would work apparently, but never pulled the trigger. had the correct off set too. That is WRONG, they are NOT 4.5 inch or 114.3 mm. They are 115 mm which is different. All 2005 on Dodge Magnum and Chrysler 300's, 2006 on Dodge Chargers and 2008 on Challengers are the 115 mm bolt circle.Putting the 5 on 4.5 inch (114.3 mm) bolt pattern wheels puts a side load on the wheel studs that they weren't designed for. The tapered seat lug nuts will be forced out of proper centering. You would be the one who is wrong. I have a set of those rims on my 51 Plymouth. Bought them new, Dorman 939-137. Go look at the applications, too. https://www.dormanproducts.com/p-66648-939-137.aspxBolt Pattern: 5 x 114.3 Fits the center hub perfectly as well. Rockauto has them under $60 a corner. https://www.rockauto.com/en/parts/dorman,939137,wheel,7644 Backspacing is different so test fit carefully. I bought one and did a tire mockup on it http://www.yourolddad.com/tiresVideo of the clearance, read the above first to make sense of the video. https://youtu.be/6RPL7KxFXGc
Re: 2019 Charger
[Re: volaredon]
#3218798
03/07/24 09:27 AM
03/07/24 09:27 AM
Sniper
nowhere
My question is why in the He11 did they have to bastardize everything and change it to metric? SAE was just fine for HOW long? I grew up with 1/8s, 1/16ths, 1/4"s and thousandths of an INCH. I have thousands of dollars spent (hate to think how many more $$it would have been if it was all spent in 2024 dollars) in saw tooling that I can't hardly use anymore. I mean I do a little at home since I got so much older stuff... But almost never at the job... It's the Borg effect. You will be assimilated, resistance is futile.
