Block heaters ? #3216877
02/28/24 07:16 PM
02/28/24 07:16 PM
BigFish69 Offline OP
Does anybody use freeze plug block heater with good results with out leaks in there race cars.
thanks Tom
Re: Block heaters ? [Re: BigFish69] #3216882
02/28/24 07:45 PM
02/28/24 07:45 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
While not a race car, the car does get raced, I’ve been using one since 2017 with no problems
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Block heaters ? [Re: metallicareload] #3216885
02/28/24 07:53 PM
02/28/24 07:53 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Had them in my 2 Dailies, used them in winter when they sat outside - worked fine.
Buddy has one in his racecar, no problems.
I think they're a good idea, as is an oilpan heater, which I've had in the racecar.
Re: Block heaters ? [Re: topside] #3216890
02/28/24 08:14 PM
02/28/24 08:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I like the ones that go in the lower radiator hose better. If it happens to fail it's easier to replace too.
Re: Block heaters ? [Re: BigFish69] #3216893
02/28/24 08:28 PM
02/28/24 08:28 PM
AndyF Offline
AndyF  Offline
I had a 1978 Dodge truck with a 440 engine that had core plug heaters. It really helped get that old beast started in the winter. Without the block heaters it would not start once the temp was down around freezing. They'll work just fine on a race engine but you do have to plug them in a couple of hours before you start the engine. They take a while to heat things up.
Re: Block heaters ? [Re: AndyF] #3216899
02/28/24 08:46 PM
02/28/24 08:46 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Up here we use them in everything, except some new diesels don't come with a block heater for some reason. I have never had one leak, just burn out. In the trucks we always ran 2, and we ran the 600w ones, one in each side, which is about as much as single receptacle can handle. 1200w/120v=10 amps.
Re: Block heaters ? [Re: Uberpube] #3216912
02/28/24 09:23 PM
02/28/24 09:23 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Friends wifes car was hard starting in cold weather. Put a lower radiator hose heater on it. Car then started fine, and blew warm air out of vents when she left for work. Only works if hose doesn't have a spot that traps air in it though.
Re: Block heaters ? [Re: BigFish69] #3216939
02/28/24 11:26 PM
02/28/24 11:26 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
thanks Tom
My son got his from Jegs for his small block. Saves him a lot of alcohol
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Block heaters ? [Re: pittsburghracer] #3216967
02/29/24 05:52 AM
02/29/24 05:52 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
i have them on everything i own.jegs sells them
Re: Block heaters ? [Re: dart games] #3216984
02/29/24 09:45 AM
02/29/24 09:45 AM
Do you install them with any rtv or just lube the o ring.
Re: Block heaters ? [Re: BigFish69] #3217069
02/29/24 02:43 PM
02/29/24 02:43 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I want to say they have an o-ring on them and go in dry? If you do use one of the block type do yourself a favor and pick a spot that is easy to access, and not buried behind a motor mount or the headers. Also the plugs may not fit in just any hole depending on where the cylinder is behind the freeze plug opening. I tried putting one in a siamese bore 400 sbc years ago and could not get it to fit so I had to use the lower radiator hose type instead.
