8 3/4 help #3216380
02/26/24 03:58 PM
02/26/24 03:58 PM
IL
dakotaman Offline OP
IL
Hello all,
I am building a Dodge Dakota. I have installed a E Body 8 3/4. It has a 489 case, that came out of a 73 D150. It is a sure grip. I had someone put a Richmond 3.90 gear set in it.
With the truck up in the air both tires will spin together in the same direction as one would expect. When trying to do a burnout I am only getting one tire to spin. I'm assuming the clutches are wore out, but I don't know enough about them. Could it be something else such as axle bearing preload? It is the only thing I can think of other than the clutches are junk. Is there a way to check the clutches without taking it apart?
I've not delt with the rearend gears much, and with the local guys wanting an arm and a leg to fix what I have I think I may try it myself. If the clutches are a pain, I may just install a spool.
Thanks in advance,
Sean
Re: 8 3/4 help [Re: dakotaman] #3216385
02/26/24 04:07 PM
02/26/24 04:07 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Originally Posted by dakotaman
Hello all,
Thanks in advance,
Sean
Have you changed the gear oil, and if so, did you add friction modifier?
Re: 8 3/4 help [Re: dakotaman] #3216407
02/26/24 05:33 PM
02/26/24 05:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hello all,
Thanks in advance,
Sean
I'm going to assume it still has the cone type sure grip , if so that is your problem , they are not designed to be rebuilt , they can be machined so the cones are not bottoming out but it's only going to happen again. They are garbage by design , they grind themselves into tiny chips of metal everytime it goes around a corner.
There is a Korean sourced copy of the dana/spicer clutch type that's less than 300 and I've heard good things about it , save yourself and just get that.
Re: 8 3/4 help [Re: JohnRR] #3216419
02/26/24 06:13 PM
02/26/24 06:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You do NOT want a spool on the street.
Re: 8 3/4 help [Re: Fat_Mike] #3216420
02/26/24 06:13 PM
02/26/24 06:13 PM
IL
IL
Hey Fat_Mike,
I probably have 5 miles on it and yes, I added Friction additive when I filled it. I've only driven it down the road a few times to shake it down.
Re: 8 3/4 help [Re: JohnRR] #3216421
02/26/24 06:15 PM
02/26/24 06:15 PM
IL
IL
JohnRR,
How do you tell if it is the cone type? I will google search it. I will probably pull the center section this upcoming weekend.
Re: 8 3/4 help [Re: stumpy] #3216422
02/26/24 06:17 PM
02/26/24 06:17 PM
IL
IL
Thanks Stumpy,
I know that a spool can be dangerous and can chew up some tires, put it will probably be 90% drag vehicle.
Re: 8 3/4 help [Re: dakotaman] #3216439
02/26/24 07:58 PM
02/26/24 07:58 PM
IMGTX Offline
IMGTX  Offline
JohnRR,
This may help.
http://www.moparts.org/Tech/Archive/axle/13.html
Re: 8 3/4 help [Re: dakotaman] #3216460
02/26/24 09:21 PM
02/26/24 09:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
JohnRR,
Who put the gears in it ? Now that the gears are setup it's not to hard to change out the diff , check current backlash setting and reset the backlash after you change the diff. You'll need new bearings for the diff.
Look at the link above , the cone type is the top picture , it is easily identified by the springs in the window.
Re: 8 3/4 help [Re: dakotaman] #3216475
02/26/24 10:10 PM
02/26/24 10:10 PM
I put a 35 spline spool and axles in my old pump gas Duster, I used an early(1964 Dodge B body) B body 8 3/4 housing and had it cut down to be 2 inches narrower than the stock Duster 8 3/4 housing. I built that car to race the blacks guys in Los angles on the streets devil It was a ladder bar car with coil over rear suspension, stock gas tank.
it was a little bit of a pain to back up while making a sharp turn to back into a parking spot that had a lot of cars in the lot, same thing on going forward around tight corners. Other than that it was good up twocents
I didn't have back brace put on that housing and I ended up bending the passenger axle side of the housing really badly, it broke the welds of the housing ladder bar mounts off of the housing doing a burn out shock puke tsk That was really lucky for me, if it had broken while racing or driving it on the streets it I may have lost control and wreck the car down shock work
I bought used Dana 60 3/4 ton pickup housing out of a junkyard that had one ruin end on it by spinning one outer wheel bearing inner race, I had it narrowed and put new ends on it and love it from day one up I used a spool in it also up
IHTHs
Re: 8 3/4 help [Re: JohnRR] #3216485
02/26/24 11:13 PM
02/26/24 11:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
JohnRR,
I will add to check the back lash in 3 or 4 positions noting them on the gear, try to get as close as possible the the existing numbers wink
Re: 8 3/4 help [Re: TJP] #3216487
02/26/24 11:16 PM
02/26/24 11:16 PM
GA
roadrunninMark Offline
GA
Hi JohnRR, do you have anymore info on the Korean diff copy? Did a google search and got some weird results but not what I was looking for.
Re: 8 3/4 help [Re: dakotaman] #3216541
02/27/24 09:34 AM
02/27/24 09:34 AM
an8sec70cuda Offline
There's nothing wrong w/ a spool on the street. Slow speed turns require a little more effort and pushing the car while turning is difficult. Other than that, you'll probably never notice a difference.
Don't believe the myths about wet roads and curves are dangerous w/ a spool.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 3/4 help [Re: roadrunninMark] #3216585
02/27/24 12:46 PM
02/27/24 12:46 PM
moparx Offline
moparx  Offline
do NOT search for korean rears.................. panic whistling laugh2
beer
Re: 8 3/4 help [Re: moparx] #3216591
02/27/24 01:00 PM
02/27/24 01:00 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Dakotaman - take your truck over to an empty parking lot and do 10 to 20 figure 8's (slowly). The friction fluid has to get in-between the cones.
Same thing happened to me on my 489 case.
Re: 8 3/4 help [Re: 76Beeper] #3216632
02/27/24 02:49 PM
02/27/24 02:49 PM
Kirkland, Washington
Pacnorthcuda Offline
friction modifier solves a problem of the diff binding up and not allowing a ‘limited slip’, his problem is UNlimited slip from worn out cones.
Re: 8 3/4 help [Re: Pacnorthcuda] #3216645
02/27/24 03:22 PM
02/27/24 03:22 PM
NJ
EV2RTSE Online content
EV2RTSE  Online Content
NJ
Re: 8 3/4 help [Re: moparx] #3216647
02/27/24 03:24 PM
02/27/24 03:24 PM
GA
GA
beer
lol Too late! My computer now smells funny…
Re: 8 3/4 help [Re: moparx] #3216671
02/27/24 05:44 PM
02/27/24 05:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
beer
haha
Re: 8 3/4 help [Re: EV2RTSE] #3216673
02/27/24 05:53 PM
02/27/24 05:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by EV2RTSE
I would not buy the china one on amazon.
I'll see the guy that told me about the Korean sourced one and find out exactly which it is .
Dr. Diff is doing something extra to the ones he is selling so that would cost extra over his cost to buy the unit
Quote
These are not the same units offered by others. I blueprint the clutch tension with hardened shims I produce myself.
