69 B body master cylinder mounting #3216226
02/25/24 11:59 PM
02/25/24 11:59 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Can I see your pics of 69 B body master cylinder mounting?
Mines has 4 studs through ms with nuts on the inside. Seems backwards to me?
Manual drum brakes please? Thanks, Don
Re: 69 B body master cylinder mounting [Re: cudadon] #3216234
02/26/24 01:09 AM
02/26/24 01:09 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Do you have the adapter plate for manual brakes? The studs go through so you can get to the inside while it sits still and put the nuts on.
I want my fair share
Re: 69 B body master cylinder mounting [Re: SomeCarGuy] #3216247
02/26/24 06:15 AM
02/26/24 06:15 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Manual brakes has studs on the master cly and power has the studs on the booster. Just carefully drive the studs out and secure them to the new master cly if you are going back with manual brakes.
Re: 69 B body master cylinder mounting [Re: fastmark] #3216272
02/26/24 10:06 AM
02/26/24 10:06 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What the OP has is correct. Since the m/c he has has four studs it is a cast iron stock style. Now he needs the correct m/c backing plate for manual brakes - it will have a round hole instead of the wierd-shaped one.
Those studs are what help secure the pedals to the firewal - so they are necessary. While it is "uncomfotable" to install, its not a big deal. The studs are accessible inside the car to install the nuts.
There is no adapter required for this unit - only needed for the late model aluminum 2-bolt m/c's
Re: 69 B body master cylinder mounting [Re: SomeCarGuy] #3216299
02/26/24 11:30 AM
02/26/24 11:30 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
From what you said I think I do have the adapter plate. Here's a picture
Re: 69 B body master cylinder mounting [Re: cudadon] #3216304
02/26/24 11:43 AM
02/26/24 11:43 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Thanks everyone for your help. Too bad the factory didn't put the studs on the inside. As I get older I need more room to work under the dash so I took the seat out. I was worried the brake pedal bracket would fall down.
I have a 69 Dodge service manual and it says take off 4 nuts and plunger bolt easy as pie.
Thanks, Don
Re: 69 B body master cylinder mounting [Re: cudadon] #3216311
02/26/24 12:05 PM
02/26/24 12:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Yup, that's it.
Re: 69 B body master cylinder mounting [Re: Stanton] #3216319
02/26/24 12:56 PM
02/26/24 12:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I regard that plate as more of a reinforcement, but no matter.
It should be a fairly glossy black.
Agree on under-dash work: probably my least favorite.
