Body dolly for 71 b body #3215275
02/22/24 12:44 AM
02/22/24 12:44 AM
Berlin NJ
scottk Offline OP
scottk  Offline OP
Berlin NJ
Wondering what the preferred dolly is. I prefer not to fabricate my own and I've seen the ones that bolt on to the k frame mounting points and the front spring perch location in the rear. I fear this style would be a little tippy as they are so close together. I was considering this one. What do you guys think? Thanks.
https://autotwirler.com/product/elite-body-cart/
Re: Body dolly for 71 b body [Re: scottk] #3215278
02/22/24 02:47 AM
02/22/24 02:47 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Looks OK. Only concern would be firmly securing where frame rails rest on uprights.
Re: Body dolly for 71 b body [Re: PhillyRag] #3215311
02/22/24 09:16 AM
02/22/24 09:16 AM
Berlin NJ
scottk Offline OP
scottk  Offline OP
Berlin NJ
I know what you mean. Hit a bump and the whole car slides.
Re: Body dolly for 71 b body [Re: scottk] #3215319
02/22/24 10:37 AM
02/22/24 10:37 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I build both styles. Which you use depends on what you’ doing. The bolt on units are fine. The front end will be light with all the sheet metal removed but so what!
Re: Body dolly for 71 b body [Re: scottk] #3215509
02/22/24 10:23 PM
02/22/24 10:23 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Just love their definition of "We use the same clamps we used on our AutoTwirler PRO so there is absolutely zero wobble on the posts".
It's a bolt that screws into the post!!!!
Seems the Plus-Body-Cart has means to bolt it onto frame rails it seems.
Re: Body dolly for 71 b body [Re: PhillyRag] #3215511
02/22/24 10:37 PM
02/22/24 10:37 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've been contemplating building a dolly. What would be wrong with using pins that go into the reference holes in the unibody frame rails? If you had a stop so the pin only went in 1 1/2" or so, wouldn't that both support the car and prevent it from sliding?
Re: Body dolly for 71 b body [Re: 6PakBee] #3215540
02/23/24 07:51 AM
02/23/24 07:51 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I made my own but it bolts to the front spring mount and the the 4 bolts for the K frame(3 pieces). It's not that hard to make, just get the correct caster wheels.
Re: Body dolly for 71 b body [Re: Moparite] #3215578
02/23/24 11:14 AM
02/23/24 11:14 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's your plan for the car ?? If its a full restoration then don't waste your time or money on the dolly or dolly stands, go with a rotisserie.
A rotisserie will allow you easy access to all areas of the car. However, if the car needs a lot of sheet metal or frame work then you can't do that on a rotisserie.
The dolly "ok" at best. It will give you access BUT the rails connecting the four corners will be in the way when you're working under the car. If they're down low you have to crawl over them. If they're up high they're in your way working on the bottom.
The four point posts and casters are a good way to go as long as the mounting points are solid. As I previously mentioned, the front end will be light once the sheet metal is removed but unless you don't climb in the trunk its a non-issue. And its an issue easily resolved with a jackstand under the back.
Re: Body dolly for 71 b body [Re: Stanton] #3215592
02/23/24 12:29 PM
02/23/24 12:29 PM
SW CO
HemiSportFury Offline
SW CO
Either of these approaches would be a better option.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Body dolly for 71 b body [Re: HemiSportFury] #3216504
02/27/24 12:22 AM
02/27/24 12:22 AM
Berlin NJ
scottk Offline OP
scottk  Offline OP
Berlin NJ
Decided on these. We'll see what happens. Thanks everyone for the input. https://www.summitracing.com/parts/WMP-MPC-0440
Re: Body dolly for 71 b body [Re: scottk] #3216670
02/27/24 05:44 PM
02/27/24 05:44 PM
SW CO
SW CO
That should do the job just fine. Not a bad price for what you are getting.
Re: Body dolly for 71 b body [Re: HemiSportFury] #3216686
02/27/24 07:10 PM
02/27/24 07:10 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Agree, and I have those same ones on my car right now, you do at first wonder if it might be prone to tipping but I've had no issues, trailered it back and forth for paint no problem at all. I think for the money they're hard to beat, some competitors are offering the same thing for a few hundred bucks more.
Re: Body dolly for 71 b body [Re: scottk] #3216716
02/27/24 09:42 PM
02/27/24 09:42 PM
AndyF Offline
AndyF  Offline
I have a set of bolt on ones for sale. I used them on my Duster project and they worked fine. A '71 B body is a bit bigger and heavier so you might want some reinforcements.
