I put a stroker kit in my 426 hemi and I have the rotating assembly and cam that I don’t need This is a stock 8 bolt crank with h beam rods Keith black pistons and arp bolts Standard bore
The cam is flat tappet hydraulic
Series:
Voodoo
Make:
Chrysler
Engine:
426 HEMI
RPM Range:
1800 to 6200
Camshaft Type:
Hydraulic Flat Tappet
Intake Valve Lift: .501"
Exhaust Valve Lift: .537"
Advertised Intake Duration: 268°
Advertised Exhaust Duration: 276°
Intake Duration @ .050": 226°
Exhaust Duration @ .050": 234°
Lobe Separation: 110°
I bought this engine complete and running in a 69 gtx
It was a mopar performance engine that was built by the previous owner of the car
Everything is in usable condition I just swapped it out for the stroker and a roller cam
There is some wear on one of the counterweights that could easily be polished out
Local pickup preferred as the weight would make it expensive to ship
I will be at the Indy swap meet next weekend if you’re going that way I’ll
www.facebook.com/marketplace/item/1191763848897471
Master, again and still
