1973 Duster 318 4bbl $17,000 #3214621
02/19/24 02:01 PM
02/19/24 02:01 PM
La Verne, CA
lakerism Offline OP
lakerism  Offline OP
La Verne, CA
Re: 1973 Duster 318 4bbl $17,000 [Re: lakerism] #3214633
02/19/24 02:28 PM
02/19/24 02:28 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
What a weird rear axle swap to do on that car.
Earning every penny of that moderator paycheck.
DBAP
Re: 1973 Duster 318 4bbl $17,000 [Re: not_a_charger] #3214643
02/19/24 02:45 PM
02/19/24 02:45 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
iagree And for a little 318 cid motor. Maybe he was planing on putting a whole ford drive train in it.
My Monster are real!
Living within your means makes life pretty easy.
Re: 1973 Duster 318 4bbl $17,000 [Re: 67vertman] #3214648
02/19/24 02:53 PM
02/19/24 02:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Maybe the guy wanted disc brakes on the rear ?
I would think that a 318 Duster would have an 8.75, but I could be wrong on that.
I'd be remiss if I didn't complain about the boy-racer (or is that boy-ricer ?) wing laugh2
That and the black hood - another mod that just looks odd to me - hurt the car, but obviously some folks like that stuff.
Seems like a pretty clean car, given the few photos posted.
Re: 1973 Duster 318 4bbl $17,000 [Re: topside] #3214649
02/19/24 02:57 PM
02/19/24 02:57 PM
The wing is awful, as all go/gull wings are. It looks like a good car, reasonable price.
DBAP
Re: 1973 Duster 318 4bbl $17,000 [Re: topside] #3215021
02/20/24 09:21 PM
02/20/24 09:21 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Seller showed pics of the axle, but zero mention of the brakes on the car ? shruggy
I think my Duster's (originally a 318) axle is original, to the car, have to check the Broadcast sheet though.
I don't like the mis-matched green wheel center caps.
Plymouth Makes It!
Re: 1973 Duster 318 4bbl $17,000 [Re: not_a_charger] #3215029
02/20/24 10:17 PM
02/20/24 10:17 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
It should be an 8.8, seems to be the cheap way to run a decent rear now a days. see a lot of the cheap turbo ls guys using that rear, usually out of an explorer. One axle is longer than the other so they cut down the long side and use two short side axles.
