Wash a car cover ? #3214917
02/20/24 01:47 PM
02/20/24 01:47 PM
md
mopars4ever Offline OP
md
Can a car cover be washed? If so, it looks too big for a standard washer. Any ideas?
Re: Wash a car cover ? [Re: mopars4ever] #3214919
02/20/24 01:54 PM
02/20/24 01:54 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have dropped several at a local laundry to be washed and they have come out okay.
Mildew stains won't come out but all the dirt does.
My last was pretty new and I asked them to use a mild detergent and it came out great.
A couple of these were for a D3500 Crew Cab Dually with a camper shell so they were big.
Re: Wash a car cover ? [Re: mopars4ever] #3214920
02/20/24 01:54 PM
02/20/24 01:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The large capacity centerless ones they have at larger laundromats
First, shop vacuum the dust out of the cover while it on the car or hanging on a clothesline. While on a car it easier. You'll see night and day difference right there.
After that, if you have compressed air, blow it out from the inside out.
Then, wash it.
**I've found that vacuuming every 1/2 to full year is great maintenance.
Re: Wash a car cover ? [Re: mopars4ever] #3214922
02/20/24 01:57 PM
02/20/24 01:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Laundromat, they have washers and dryers large enough to handle the size and usually a large spin/rinse unit to handle that too. Maybe check with the cover manufacture if it is possible to wash, spin and dry?
Re: Wash a car cover ? [Re: A12] #3214927
02/20/24 02:10 PM
02/20/24 02:10 PM
md
md
Not sure on manufacturer or type. The cover came with the car. I was just worried it would fall apart or something. I assume air dry only? I give it a try, thanks to all.
Re: Wash a car cover ? [Re: mopars4ever] #3214938
02/20/24 03:07 PM
02/20/24 03:07 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I wash my old cotton, non-elastic covers every couple of years & they get dried in the dryer.
Old in this case means about 35-40 years old.
Quite a bit of lint in the dryer filter, but the covers are still holding together.
One at a time fills the washer & dryer, which are normal household size.
I shake them out before washing to get the dust off.
I've washed & dried the quilted Dually cover at a laundromat - it's huge.
f t was a tent, it would have an occupancy rating of at least 12 laugh2.
Re: Wash a car cover ? [Re: topside] #3214941
02/20/24 03:16 PM
02/20/24 03:16 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't own one of the expensive covers, just a basic nylon one. All I want to do is keep dirt and dust off the car, not keep it warm and cozy! That said, I routinely wash mine in our washer. It used to get knotted up around the spindle but we now have a "front loader" so it doesn't have that issue any more. And I either toss it in the dryer or on the line. Being nylon it dries in no time.
Re: Wash a car cover ? [Re: Stanton] #3214943
02/20/24 03:25 PM
02/20/24 03:25 PM
Aren't a lot of the newer covers basically paper now?
Re: Wash a car cover ? [Re: Cab_Burge] #3214966
02/20/24 04:11 PM
02/20/24 04:11 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Does the cover have a tag with how to wash instructions? I want to say some of the water proof outdoor rated covers have specific instructions on how to clean them so as to not mess up the waterproofing feature.
If it's just dusty I would grab a helper and shake it out really well, and/or vacuum it.
Drying it could be done on a hot summer day just by putting it outside spread over some lawn furniture, etc. to keep it off the ground.
Re: Wash a car cover ? [Re: Neil] #3214977
02/20/24 05:46 PM
02/20/24 05:46 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
nylon cover will turn into a solid ball in dryer, play it safe air dry
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Wash a car cover ? [Re: 440lebaron] #3214994
02/20/24 07:15 PM
02/20/24 07:15 PM
md
md
no instructions, tag says Oxgord
Re: Wash a car cover ? [Re: mopars4ever] #3215032
02/20/24 10:42 PM
02/20/24 10:42 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There's always that one person ...
Quote
Bought the cover around 1989. Wash it at least twice a year and almost always toss it in the dryer. And its on the car right now !!!
Nylon 6 fibers are tough, possessing high tensile strength, elasticity, and luster. The fibers can absorb up to 2.4% of water, although this lowers tensile strength. The glass transition temperature of nylon 6 is 47 °C. Nylon 6 is generally white as a synthetic fiber but can be dyed in a solution bath before production for different color results. The tenacity of nylon 6 is 6–8.5 gf/D with a density of 1.14 g/cm3. Its melting point is 215 °C and can protect heat up to 150 °C on average.
The applications of nylon 6 include construction material in many industries, including the automotive industry, electronic and electrotechnical industry, aircraft industry, clothing industry, and medicine.
215*C is 419*F ... you roast a turkey at a lower temp than that !!!
Re: Wash a car cover ? [Re: Stanton] #3215036
02/20/24 11:16 PM
02/20/24 11:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I bought one of the kimberly clark magic outdoor covers back about 94 or so as the car was parked outside. The cover always had a strange dirty feel to it. Washed it several times at a laundromat per instructions and air dried. It did its job but was prone to tearing at the antenna hole.
My other cover that was purchased in about 83 is 100% cotton and still hanging in there. Don't think I'll ever buy anything but a cotton cover again twocents beer
Re: Wash a car cover ? [Re: autoxcuda] #3215046
02/21/24 12:13 AM
02/21/24 12:13 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Then, wash it.
iagree up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Wash a car cover ? [Re: BloFish] #3215112
02/21/24 11:46 AM
02/21/24 11:46 AM
K
Kiddart Offline
Kiddart  Offline
K
I have two Nylon stretch covers. wash in cold water with two rinse cycles. Use wool lite for detergent.
In the dryer run on no heat or fluff and it will dry very nicely. Keep an eye on it so it doesn't ball up or put tennis balls in the dryer with it.
COLD WATER AND DRY NO HEAT.
Thank you
Kiddart
Re: Wash a car cover ? [Re: Kiddart] #3215166
02/21/24 03:26 PM
02/21/24 03:26 PM
5thAve Offline
5thAve  Offline
A friend of mine with access to commercial washers has done mine before. No issues.
Re: Wash a car cover ? [Re: mopars4ever] #3215254
02/21/24 10:08 PM
02/21/24 10:08 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I take mine to the local drycleaners. They have industrial size washers. Comes back folded in a box. Mine is 25 yrs old and looks like its still new.
Ok
