Re: Wash a car cover ?
[Re: mopars4ever]
#3214920
02/20/24 01:54 PM
02/20/24 01:54 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Can a car cover be washed? If so, it looks too big for a standard washer. Any ideas? The large capacity centerless ones they have at larger laundromats First, shop vacuum the dust out of the cover while it on the car or hanging on a clothesline. While on a car it easier. You'll see night and day difference right there. After that, if you have compressed air, blow it out from the inside out. Then, wash it. **I've found that vacuuming every 1/2 to full year is great maintenance.
[Re: mopars4ever]
#3214938
02/20/24 03:07 PM
02/20/24 03:07 PM
Posts: 20,913 A collage of whims
topside
A collage of whims
I wash my old cotton, non-elastic covers every couple of years & they get dried in the dryer. Old in this case means about 35-40 years old. Quite a bit of lint in the dryer filter, but the covers are still holding together. One at a time fills the washer & dryer, which are normal household size. I shake them out before washing to get the dust off. I've washed & dried the quilted Dually cover at a laundromat - it's huge. f t was a tent, it would have an occupancy rating of at least 12 .
[Re: Stanton]
#3214943
02/20/24 03:25 PM
02/20/24 03:25 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Aren't a lot of the newer covers basically paper now?
[Re: Neil]
#3214977
02/20/24 05:46 PM
02/20/24 05:46 PM
Posts: 1,612 westerly, ri. usa
440lebaron
westerly, ri. usa
nylon cover will turn into a solid ball in dryer, play it safe air dry
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: mopars4ever]
#3215032
02/20/24 10:42 PM
02/20/24 10:42 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
There's always that one person ... nylon cover will turn into a solid ball in dryer, play it safe air dry Bought the cover around 1989. Wash it at least twice a year and almost always toss it in the dryer. And its on the car right now !!! Nylon 6 fibers are tough, possessing high tensile strength, elasticity, and luster. The fibers can absorb up to 2.4% of water, although this lowers tensile strength. The glass transition temperature of nylon 6 is 47 °C. Nylon 6 is generally white as a synthetic fiber but can be dyed in a solution bath before production for different color results. The tenacity of nylon 6 is 6–8.5 gf/D with a density of 1.14 g/cm3. Its melting point is 215 °C and can protect heat up to 150 °C on average. The applications of nylon 6 include construction material in many industries, including the automotive industry, electronic and electrotechnical industry, aircraft industry, clothing industry, and medicine. 215*C is 419*F ... you roast a turkey at a lower temp than that !!!
[Re: autoxcuda]
#3215046
02/21/24 12:13 AM
02/21/24 12:13 AM
Posts: 16,543 On the run…
BloFish
On the run…
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3215112
02/21/24 11:46 AM
02/21/24 11:46 AM
Posts: 1,559 Michigan
Kiddart
I have two Nylon stretch covers. wash in cold water with two rinse cycles. Use wool lite for detergent. In the dryer run on no heat or fluff and it will dry very nicely. Keep an eye on it so it doesn't ball up or put tennis balls in the dryer with it.
COLD WATER AND DRY NO HEAT.
Thank you Kiddart
[Re: mopars4ever]
#3215254
02/21/24 10:08 PM
02/21/24 10:08 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I take mine to the local drycleaners. They have industrial size washers. Comes back folded in a box. Mine is 25 yrs old and looks like its still new.
Ok
