Re: Distributor nylon shaft end bushings
[Re: volaredon]
#3214676
02/19/24 04:27 PM
02/19/24 04:27 PM
Posts: 4,680 Wichita
GY3
Wichita
You can buy them dirt cheap at Lowes.
They are a Hillman brand.
[Re: A12]
#3214710
02/19/24 06:39 PM
02/19/24 06:39 PM
GY3
Wichita
Over $20 for a nylon collar?!? The ones at Lowes were 99 cents for two as I recall!
[Re: A12]
#3214725
02/19/24 07:25 PM
02/19/24 07:25 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Notice the shaft is not drilled for the pin location, I don't know if that collar is drilled as I have taken collars off and they only go back one way , drilled offset?
[Re: JohnRR]
#3214964
02/20/24 03:58 PM
02/20/24 03:58 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Laters Mopar pieces sold in plastic bags aren’t drilled either.
[Re: convx4]
#3216282
02/26/24 10:41 AM
02/26/24 10:41 AM
Posts: 16,148 Mesa, Arizona
dart4forte
Mesa, Arizona
I use the aluminum collars. I bought a bag of them 20 years ago when they were cheap.
Abe Lincoln
[Re: convx4]
#3216317
02/26/24 12:38 PM
02/26/24 12:38 PM
GY3
Wichita
I have a couple distributor machines and have spent much time rebuilding mopar dizzys. In my opinion the Hillman brand bushings should only be used in an emergency. They do not fit snugly on the undersized shaft diameter of the dizzy. I have had the Hillman bushings on multiple cars and never an issue! The one on my car has been there for 10 years, 9,000 miles and hundreds of dragstrip passes. I'm not sure anyone does destructive testing better than me.
