OEM style undercoating #3214613
02/19/24 01:47 PM
02/19/24 01:47 PM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
What have you guys found for an aftermarket undercoating that replicates the Mopar oem style undercoating on our typical 66-72 era cars? I have tried several over the years and never really been happy with the results. Closest I have found is 3M Body Shutz but it is awfully messy if you are just trying to patch a small area. Any ideas or suggestions?? (Yes, I understand I can scrape it all off but my hemi GTX has it and I want to touch it up)
Re: OEM style undercoating [Re: 2JcodeChargers] #3214640
02/19/24 02:36 PM
02/19/24 02:36 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Re: OEM style undercoating [Re: Neil] #3214650
02/19/24 03:00 PM
02/19/24 03:00 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
My Monster are real!
Living within your means makes life pretty easy.
Re: OEM style undercoating [Re: 67vertman] #3214686
02/19/24 05:01 PM
02/19/24 05:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I tried a bunch of stuff on a '63 I did years ago - all too thin & "watery".
Bought some Resto Rick stuff and it was WAY better.
Still a bit thin even with a schutz gun, takes multiple coats.
Anything you use is messy as hell; put plastic drop-cloths everywhere !
Factory stuff looks like stucco, and obviously hosed on.
Re: OEM style undercoating [Re: 2JcodeChargers] #3214719
02/19/24 07:14 PM
02/19/24 07:14 PM
Mass
charge70 Offline
charge70  Offline
Mass
I use Resto-Ricks undercoat. I've found many thin coates with lower than specked air pressure works best.Let it air dry over nite 1or 2 lite coates next day and call it done.See any spots you don't like,touch them up.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: OEM style undercoating [Re: charge70] #3215120
02/21/24 12:21 PM
02/21/24 12:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've been using Rusfre with a little reducer (spirits) added and am satisfied with the results.
Bonus, in my area it's available locally for the same price as it is online.
Rich H.
Esse Quam Videri
