Page 2 of 3 1 2 3
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3212040
02/08/24 05:45 PM
02/08/24 05:45 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Originally Posted by GODSCOUNTRY340
This is the C body manifold I have. (pic)
Have it angle milled for outlet to tuck more to block then remove the outlet, weld in a 2-1/2” pipe with a flange. Accurate made one like that a few years back, worked nice. Might need a shield over factory starter.
Re: Who sells the big block A body exhaust manifold? [Re: cudaman1969] #3212068
02/08/24 07:36 PM
02/08/24 07:36 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I just sold my Accurate manifold for $1000 last year as I was never going to use it. Not sure if I have a picture of it available... work Edit:: found a picture...
JB Rhinehart, Realist
A-Body's RULE!
Re: Who sells the big block A body exhaust manifold? [Re: Rhinodart] #3212916
02/11/24 11:52 PM
02/11/24 11:52 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mike you can make that with what you already have...
...FAFO...
Re: Who sells the big block A body exhaust manifold? [Re: skicker] #3213149
02/12/24 11:10 PM
02/12/24 11:10 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
I wish someone had a pic with that manifold in relation to where it would dump out at the Z BAR! This is the main problem, it may fit an automatic car but what about a 4 speed car?
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3213162
02/13/24 02:22 AM
02/13/24 02:22 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I don't know if any of these photos will be of help or show what you need? This is my friend's M-Code 440 Dart that I have a lot of photos of but not exactly of what you may need? I'll include what I also have of the passenger's side exhaust manifold. Photo 4788 deliberately over exposed to show more down there.
Mike
Re: Who sells the big block A body exhaust manifold? [Re: A12] #3213163
02/13/24 02:32 AM
02/13/24 02:32 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Some more of the driver's side and the right/passenger's side.
Hope this helps?
Mike
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3213164
02/13/24 03:50 AM
02/13/24 03:50 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
A search came up with this page, it has a fair amount of pics and some info.
https://web.archive.org/web/20160804054936/http://www.bigblockdart.com/techpages/HPman.shtml
Another pic of the Accurate manifold for the drivers side.
It's shown at the bottom of that page.
Re: Who sells the big block A body exhaust manifold? [Re: SNK-EYZ] #3213166
02/13/24 04:36 AM
02/13/24 04:36 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Which one(s) of these Is an original big block OEM exhaust manifold for the driver's side?
1969_dodge_dart_20211011_162548-18054-scaled (1).jpg00000_j7dTroDubQp_600x450.jpg00u0u_gyzAK7DMT08_600x450.jpg69gts7.jpg
Re: Who sells the big block A body exhaust manifold? [Re: A12] #3213196
02/13/24 11:15 AM
02/13/24 11:15 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
They all are. The top one is the 017 M-Code 440 manifold, can't tell which year the middle picture is due to the angle but it is a 383 A-Body manifold, the bottom one is the 729 68-69 383 manifold.
A-Body's RULE!
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3213197
02/13/24 11:18 AM
02/13/24 11:18 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had that manifold on my 4-speed 69 GTS 383 and the bell crank cleared just fine. twocents
A-Body's RULE!
Re: Who sells the big block A body exhaust manifold? [Re: Rhinodart] #3213203
02/13/24 11:34 AM
02/13/24 11:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Middle one appears to not have the #3 pipe indent so that would make it the 67 ?
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3213204
02/13/24 11:35 AM
02/13/24 11:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you're thinking of making it from your C body manifold you can position that pipe where every you'd want it to clear
Re: Who sells the big block A body exhaust manifold? [Re: JohnRR] #3213210
02/13/24 12:45 PM
02/13/24 12:45 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
I had the same problem, went to a set of schumacher creative services headers that way to avoid the $$$ money hounds ! PS or not 4 speed or auto ........... hello brother Frank
Re: Who sells the big block A body exhaust manifold? [Re: B1Frank] #3213299
02/13/24 08:20 PM
02/13/24 08:20 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If you are doing a street machine no problem, but if you want a restoration then you have to buy the right parts. I have had quite a few big block A-Body's with hacked exhaust systems, no thanks! tsk
A-Body's RULE!
Re: Who sells the big block A body exhaust manifold? [Re: Rhinodart] #3214250
02/17/24 10:30 PM
02/17/24 10:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I snapped a couple pics of my modded manifold
Re: Who sells the big block A body exhaust manifold? [Re: JohnRR] #3214494
02/18/24 11:48 PM
02/18/24 11:48 PM
Thanks for all the replies and pics. All the manifolds I tried dump right into the Z bar so I decided to go with the Wilwood/McLeod hydraulic clutch conversion. Not a direct bolt in kit, had to make a 35 degree firewall adapter to get the rod to line up with the clutch pedal attachment point. Looks like I'll be using the headers after all. The seller of the kit claimed I would have to cut up my firewall to get the master cylinder to line up with the pedal. I told them I wasn't hacking up my firewall, plus there was no way to mount it where it needed to be as it would run into either the brake master cylinder or the steering column mount at the firewall. They said they were actually made for Ford & Chevy vehicles and they weren't familiar with the kit installed on a Mopar A body and really couldn't give any recommendations on how to get it to work. I'll get a pic tomorrow on how I got it to line up.
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3214517
02/19/24 04:22 AM
02/19/24 04:22 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanks for all the replies and pics. All the manifolds I tried dump right into the Z bar so I decided to go with the Wilwood/McLeod hydraulic clutch conversion. Not a direct bolt in kit, had to make a 35 degree firewall adapter to get the rod to line up with the clutch pedal attachment point. Looks like I'll be using the headers after all. The seller of the kit claimed I would have to cut up my firewall to get the master cylinder to line up with the pedal. I told them I wasn't hacking up my firewall, plus there was no way to mount it where it needed to be as it would run into either the brake master cylinder or the steering column mount at the firewall. They said they were actually made for Ford & Chevy vehicles and they weren't familiar with the kit installed on a Mopar A body and really couldn't give ant recommendations on how to get it to work. I'll get a pic tomorrow on how I got it to line up.
Re: Who sells the big block A body exhaust manifold? [Re: A12] #3214921
02/20/24 01:57 PM
02/20/24 01:57 PM
Here's the hydraulic throwout bearing being used. Need to add this, the directions say to have the bell attached to the engine and feed the trans with the throwout bearing with the hoses hooked to it through the hole in the bell. Well, they obviously have never tried this as the hydraulic throwout bearing with the hoses attached are bigger than the bell bearing retainer hole and will NOT go together like that. I had to remove the bell from the engine and angle it one way then another to get it to wiggle through, with the hoses OFF the throwout bearing.. So in reality, you have to have the bell hooked to the trans, then hook the hoses up and place them through the side of the bell to get it right. This would be a total PITA if done under the car.
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3214974
02/20/24 05:36 PM
02/20/24 05:36 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Only difference in the 370 bellhousing to the 372 they used in the big block A-Body's was the hole for the clutch rod spring was missing on the 370 as far as I can tell...
A-Body's RULE!
Re: Who sells the big block A body exhaust manifold? [Re: GODSCOUNTRY340] #3215765
02/24/24 09:39 AM
02/24/24 09:39 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
There's a pair of BB manifolds listed in the A body for sale section.
America First!
Page 2 of 3 1 2 3
