904 Transmission - Has Someone Been in Here Before? #3214029
02/16/24 09:08 PM
02/16/24 09:08 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I have an AMC A904 that I plan on putting in a '70 Javelin (Mopar adjacent). I got the transmission with the car so I have no history on it. I am transmission ignorant so when I saw a numbered plate above the valve body I didn't know if it was stock or if someone has been in the transmission before. So, looking at the picture, is this stock?
Good news was the pan looked really clean (no metal).
Re: 904 Transmission - Has Someone Been in Here Before? [Re: VITC_GTX] #3214035
02/16/24 09:27 PM
02/16/24 09:27 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Can't tell you if anyone has been there before, was the pan gasket cork? Since that trans is for AMC motor, I would at least have it resealed and would probably have it rebuilt. Its been around a very long time.
Re: 904 Transmission - Has Someone Been in Here Before? [Re: poorboy] #3214036
02/16/24 09:41 PM
02/16/24 09:41 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The gasket was not cork, black nitrile/rubber. I'd assumed someone had changed the fluid/filter before but wasn't sure about a rebuild.
I don't plan on keeping this transmission in the car too long, few months, so I'm going to roll the dice and put it in as is runaway
Re: 904 Transmission - Has Someone Been in Here Before? [Re: VITC_GTX] #3214037
02/16/24 09:44 PM
02/16/24 09:44 PM
IMGTX Offline
IMGTX  Offline
Numbered plates are normal.
Wish I could say more except just can't tell anything else about it.
If you have never built a transmission 904 and 727 are pretty easy.
Good time to start. up
Re: 904 Transmission - Has Someone Been in Here Before? [Re: IMGTX] #3214053
02/16/24 10:39 PM
02/16/24 10:39 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
That's what I was looking for. Thanks!!
Re: 904 Transmission - Has Someone Been in Here Before? [Re: IMGTX] #3214055
02/16/24 10:40 PM
02/16/24 10:40 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I'll probably give the 727 rebuild a try once I find one. up
Re: 904 Transmission - Has Someone Been in Here Before? [Re: VITC_GTX] #3214129
02/17/24 12:35 PM
02/17/24 12:35 PM
moparx Offline
moparx  Offline
a FSM and the monroe and hand books are good material to help you on the rebuild.
i refer to these often, just to keep my memory fresh.
beer
Re: 904 Transmission - Has Someone Been in Here Before? [Re: IMGTX] #3214160
02/17/24 02:52 PM
02/17/24 02:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The number in the steel plate is the last three digits of the plate's part number.
Re: 904 Transmission - Has Someone Been in Here Before? [Re: John_Kunkel] #3214233
02/17/24 08:32 PM
02/17/24 08:32 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks!
Re: 904 Transmission - Has Someone Been in Here Before? [Re: VITC_GTX] #3221627
03/20/24 10:36 AM
03/20/24 10:36 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
The 904 when built well will take a bunch of power for a good bit. Not sure what the end use of the car will be. I swapped from a 727 to 904 and the fluid looks perfect two years and 50-60 runs later.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 904 Transmission - Has Someone Been in Here Before? [Re: FurryStump] #3221664
03/20/24 01:33 PM
03/20/24 01:33 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I've done 904 to 727 before, id never go the other way
Re: 904 Transmission - Has Someone Been in Here Before? [Re: volaredon] #3221702
03/20/24 04:39 PM
03/20/24 04:39 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Funny, people have had simple 904’s live behind much higher HP/torque than most would believe. With big sticky tires.
Re: 904 Transmission - Has Someone Been in Here Before? [Re: FurryStump] #3221784
03/20/24 09:39 PM
03/20/24 09:39 PM
5thAve Offline
5thAve  Offline
Funny too that they seem to hold up for racing and not as much with normal driving mileage.
Re: 904 Transmission - Has Someone Been in Here Before? [Re: 5thAve] #3221785
03/20/24 09:44 PM
03/20/24 09:44 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
904 > 727 simple mopar math
Re: 904 Transmission - Has Someone Been in Here Before? [Re: 5thAve] #3221786
03/20/24 09:47 PM
03/20/24 09:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I put a 340 in front of a 904 in a 69 Charger (originally had a 318), and added a 3:55 rear gear. Can't say how long it was going to last, but it sure was fun the summer I put it together and beat the crap out of it. The kid down the street wanted that 69 Charger body way more then I did and he became the owner of a 69 Charger with out the motor and trans. The motor eventually ended up in my dirt track car. The trans probably got sold.
