'360 LA Short block
Bored .040
Higher compression flattop pistons
Crank turned .010/.010
ARP main bolts
King main and rod bearings
Rebuilt rods with ARP bolts
Hughes cam Hydraulic flat tappet and Lifters. See pic of the cam card.
BTR pushrods
Cloyes timing chain
Stock Windage tray
Center sump oil pan
143T 360 Flywheel
Standard clutch and pressure plate.
Motor was machined and built 2 years ago. Raced about 12 races (Dirt track), until I broke a rocker shaft. Took motor apart in December 2022, put in new bearings, new cam and lifters. Lifters and pushrods are for Magnum head conversion.Broke an intake valve and one lifter. Needs one piston and lifters. All bearings are good.
Edit* Have new lifter to replace the broken one. Flywheel is a 143t for LA 360. Piston does not need replaced, just cleaned up.
New Athens, IL
Location is approximate
www.facebook.com/marketplace/item/761289662168285
