RAS/RAU B/RB stainless rockers #3213371
02/13/24 10:34 PM
02/13/24 10:34 PM
Out of the State of Confusion
blue_stocker Offline OP
Some time ago, Gary and the boys at Rocker Arm Specialist (now known as Rocker Arms Unlimited), offered some pretty nice stainless roller tip rockers but due to production/getting materials and other 'reasons' they haven't been offered, but they're back!! Gary told me they're available in 1.6 ratio only. The earlier batches were investment cast but the current ones are now CNC machined. I got my set this afternoon and although I haven't done an analytical on them, they look pretty good! If you're interested, drop them an email or give them a call. Gary Patrick 530-242-1316 or email rockerarms@rockerarms.com.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: RAS/RAU B/RB stainless rockers [Re: blue_stocker] #3213374
02/13/24 10:46 PM
02/13/24 10:46 PM
AndyF Offline
AndyF  Offline
Looks good. CNC machining is a good move for them. They were always having troubles getting the investment castings made. It should be a simple process but for some reason they had a lot of trouble with casting vendors. I have a set of RAS rockers that have been on my engine for 30 years.
https://youtu.be/T9KlPya_z_E
Re: RAS/RAU B/RB stainless rockers [Re: AndyF] #3213468
02/14/24 12:02 PM
02/14/24 12:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Glad to see these back , I wanted a set way back when , maybe I'll off my sharps and get a set of these , but I'm scared to ask how much nervous
Re: RAS/RAU B/RB stainless rockers [Re: blue_stocker] #3213528
02/14/24 02:45 PM
02/14/24 02:45 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I've been using a set of his rockers for almost 20 years. I've probably made at least 2000 passes with them and they still have pefect clearance. They are the best investment that I've made for my engine.
Re: RAS/RAU B/RB stainless rockers [Re: blue_stocker] #3213534
02/14/24 03:04 PM
02/14/24 03:04 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Those look nice. What's a set go for these days?
Re: RAS/RAU B/RB stainless rockers [Re: mopowers] #3213544
02/14/24 04:04 PM
02/14/24 04:04 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
As I've mentioned in the past, the only reason I sold mine is due to switching to cylinder heads that required additional intake pushrod offset. I had a full set of 1.5s plus a half set of 1.6s for the intakes, too.
The only downside to those rockers is they have a high MOI, based on them having a lot of weight on the top of the valve stem compared to other rockers I checked against. Likely not an issue until the RPM gets up to some undetermined point depending upon each individual combination.
Since they're CNC-ing them now, I wonder if they are taking advantage of this and trimming off more material during the machining process. They were (are) certainly the strongest rockers I ever owned and could have easily shed some bulk and maintained sufficient strength.
Doesn't look like they're using the same beefy shafts they used to offer, either. I still have a set of those that I use now w/ Hughes rockers on my Victors. The closest I've seen as far as shaft wall thickness are the Harland Sharp shafts, but they have a different location for the oil feed holes than the RAS "banana grooved" shafts do (did?).
Nobody's said anything about a current price, so I'll take a s.w.a.g. and say $1800-2000 for a set. They were already way over $1K when I saw they still advertised them years ago and ASSume they've simply gone up since then. If they are "only" $1500 now, I'll be surprised.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: RAS/RAU B/RB stainless rockers [Re: blue_stocker] #3213546
02/14/24 04:14 PM
02/14/24 04:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
i assume they have had a FEA , and I wonder why the inside roller tip legs don't a larger in radius on the inside fillets. Seems like there should a little bit of extra clearance left over for the roller, but it's hard to judge from the pics.
Thery do look nice. What rides on the shaft, any bearings/bushings?
Re: RAS/RAU B/RB stainless rockers [Re: blue_stocker] #3213548
02/14/24 04:28 PM
02/14/24 04:28 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: RAS/RAU B/RB stainless rockers [Re: jcc] #3213553
02/14/24 05:39 PM
02/14/24 05:39 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
They have bronze bushing but the shafts have two banana grooved oil holes per rocker. They never seem to wear at all
Re: RAS/RAU B/RB stainless rockers [Re: jcc] #3213565
02/14/24 06:36 PM
02/14/24 06:36 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Originally Posted by jcc
i assume they have had a FEA ...
I don't. I assume about 25 years ago one of the RAS people saw a diagram for a truss bridge and thought it would be pretty strong if they put a fulcrum on one end and a roller tip on the other. wink
Re: RAS/RAU B/RB stainless rockers [Re: GomangoCuda] #3213641
02/15/24 12:30 AM
02/15/24 12:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted by GomangoCuda
http://rockerarms.com/pdf/pl440flyer.pdf
Looks like bronze bushing.
my dealings with them several years back and a long time ago were not good, either time down
Harland Sharp does a lot better job of taking care of business and their customers up twocents scope
Re: RAS/RAU B/RB stainless rockers [Re: Cab_Burge] #3213642
02/15/24 12:38 AM
02/15/24 12:38 AM
Like any business, they have their ups and downs. It's easy to judge when you're not in their shoes, right? Done that before myself, but in my old age I have learned to forgive and forget. They've had their share of problems over the years but their products have always been very good. They've done 7-8 sets of rockers for me (Crane/Isky/OEM small block/Max wedge). Even though they can be slow, they're products are still very good.
Thomas Jefferson
Re: RAS/RAU B/RB stainless rockers [Re: Brad_Haak] #3213668
02/15/24 09:18 AM
02/15/24 09:18 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Explain?
I don't see how what you mention really applies here nor what problem that creates anyway, that I am missing.
Regardless, I would mostly trust FEA.
Re: RAS/RAU B/RB stainless rockers [Re: Brad_Haak] #3213675
02/15/24 09:51 AM
02/15/24 09:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1095 as of yesterday when I messaged on the book of faces
Re: RAS/RAU B/RB stainless rockers [Re: jcc] #3213681
02/15/24 10:10 AM
02/15/24 10:10 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Explain?
It's a round-about way of saying I don't think the RAS/RAU people are sophisticated enough to have used FEA to design them 25 years ago when I first saw a set
Re: RAS/RAU B/RB stainless rockers [Re: JohnRR] #3213683
02/15/24 10:12 AM
02/15/24 10:12 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Looks like they've made an effort to keep the price somewhat in line, given how the cost of materials, etc. have risen over the last few years
Re: RAS/RAU B/RB stainless rockers [Re: Brad_Haak] #3213688
02/15/24 10:17 AM
02/15/24 10:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was shocked they were that cheap , if they really are that cheap I think I will sell off my Sharps and get these , I'd rather have bushed rockers than needle bearing in my application. ... stock appearing wink
Re: RAS/RAU B/RB stainless rockers [Re: Brad_Haak] #3213706
02/15/24 11:45 AM
02/15/24 11:45 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Explain?
Got it.
Re: RAS/RAU B/RB stainless rockers [Re: jcc] #3213994
02/16/24 05:48 PM
02/16/24 05:48 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Good to see that they are back. I am certain that i paid close to that for mine meny years ago. From what i can see it would appear that they have changed the way that they are oiling the push rod. Mine have a hole on the end that sprays oil onto the valve cover and then splashes back into the pushrod cup. From what I see in the photos they may have changed that.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
