Vara-Ram Air Grabber at Summit
#3213267
02/13/24 05:44 PM
02/13/24 05:44 PM
Posts: 4,684 Wichita
GY3
Wichita
I ran across this today and found it interesting...
Re: Vara-Ram Air Grabber at Summit
[Re: GY3]
#3213462
02/14/24 11:49 AM
02/14/24 11:49 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Yep, familiar....the hemi ram crowd has had them for somewhere close to 20 years.
I like the way they look, but don't know if they function any better than the other cai's out there, enough to compensate for the added complexity.
Rich H.
Esse Quam Videri
[Re: 360view]
#3213665
02/15/24 09:10 AM
02/15/24 09:10 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Would it not at the least lean towards cooler intake air?
[Re: TJP]
#3213909
02/16/24 11:08 AM
02/16/24 11:08 AM
Posts: 2,944 GA
roadrunninMark
GA
I am using this setup for a hood sealed cold air intake... https://moparconnectionmagazine.com...ld-your-own-air-grabber-with-kn-filters/I think I have under 275 in the setup, using a Summit discount. I bought the "seal" on Amazon, but you only need about 5' (compared to the link in the article). Summit items: K&N X-Stream Airflow Top Plates 66-1401, Allstar Performance Aluminum Air Cleaners ALL25923, Allstar Performance Universal Plastic Air Pans ALL26104
