Line Hone Question #3213020
02/12/24 01:33 PM
02/12/24 01:33 PM
Illinois
gearhead01 Offline OP
Illinois
Greetings!
I am getting ready to take the block for machining.
The block already has main studs. I did not build, so I do not have the full history.
I am putting in a brand new crank. Should I have have it Line Honed?
Second question - If add a girdle later with new (longer) studs, does it need to be Line Hone again with the girdle?
Thank you for your thoughts.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Line Hone Question [Re: gearhead01] #3213022
02/12/24 01:35 PM
02/12/24 01:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Have it checked and repaired as necessary. Always better to know than assume for sure.
Re: Line Hone Question [Re: gearhead01] #3213038
02/12/24 02:18 PM
02/12/24 02:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
Which motor, BB or SB, Hemi?
If a BB wedge don't waste your time and money on a crank girdle, maybe replace the stock caps with aluminum caps and main studs work scope up twocents
Mopar BB wedge motors have a lot of strength in their main webbing stock, replace the cast iron caps and go racing until the RB main webbing cracks shruggy work
How about a new race block with cross bolt mains up work scope
