Small block aftermarket AC #3212614
02/10/24 09:05 PM
02/10/24 09:05 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
1973 Charger 340 CID no factory AC. I would like to add aftermarket AC using the Sanden compressor.
There are a couple of brackets on the market to mount that compressor. No problem running 2 belts on big blocks, but only one belt on small blocks.
Question: Anyone figure out a way to mount a Sanden compressor on a small block and run two belts.(I do have correct pulleys and alternator that would normally come on AC cars as well).
It appears that the compressor crashes with the thermostat housing using any of the brackets available on the market.
I'll fabricate my own brackets to move the compressor toward driver side if I have to but I insist on running two belts.
Re: Small block aftermarket AC [Re: Gabmando] #3212616
02/10/24 09:11 PM
02/10/24 09:11 PM
BDW Online content
BDW  Online Content
I used VA bracket
Re: Small block aftermarket AC [Re: Gabmando] #3212675
02/11/24 03:51 AM
02/11/24 03:51 AM
if you want to do it all yourself, why isn't it done? confused devil stirthepot haha whistling
Re: Small block aftermarket AC [Re: BDW] #3212690
02/11/24 08:28 AM
02/11/24 08:28 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted by BDW
I used VA bracket
They get their brackets from Bouchillion, at least the ones for my poly do.
Kevin
Re: Small block aftermarket AC [Re: Twostick] #3212732
02/11/24 11:32 AM
02/11/24 11:32 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
BDW and Twostick thank you for your helpful responses. This will save me hours of fabrication.
Re: Small block aftermarket AC [Re: Gabmando] #3212735
02/11/24 11:55 AM
02/11/24 11:55 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used a Bouchillon pulley set-up for my 440-6 with Shaker hood to mount my Sanden compressor under my alternator, although I ended up using a different belt routing to allow for more belt-wrap around some of the pulleys.
https://www.bouchillonperformance.com/products-aircon-compressor-brackets
Re: Small block aftermarket AC [Re: Twostick] #3212740
02/11/24 12:04 PM
02/11/24 12:04 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Originally Posted by Twostick
[quote=BDW]I used VA bracket
Kevin
Classic Auto Air gets their brackets from Bouchillion and some work has to be done to run two belts:
https://www.forabodiesonly.com/mopar/threads/classic-auto-air-belt-alignment-fix.553777/
Re: Small block aftermarket AC [Re: 69Cuda340S] #3212744
02/11/24 12:20 PM
02/11/24 12:20 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Kevin
Well, it one ran the 79 and up 4bbl intake instead you wouldn't have that compressor to water outlet issue. You know why? Because when Chrysler switched from the R2 to the Sanden the same thing happened, so Chrysler moved the outlet.
Easier fix than the hoops jumped thru in the linked fix, not that the "fix" helped much, no one has any idea what pulleys were used.
The Performer and Torker II intake can accommodate the 79 and up style outlet set up. Not sure about other brands though,
Re: Small block aftermarket AC [Re: Sniper] #3212748
02/11/24 12:31 PM
02/11/24 12:31 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If you look on their web site they show pictures that their kit runs a single belt. People on the A Body forum are reporting belt squeals, one belt won't work, and Bouchillon just shrugs off the complaints and does nothing to help:
https://www.bouchillonperformance.com/inc/sdetail/467/572
Re: Small block aftermarket AC [Re: 69Cuda340S] #3212819
02/11/24 05:10 PM
02/11/24 05:10 PM
BDW Online content
BDW  Online Content
Not sure if it matters, but that motor had the Performer 2 intake.
I've moved on since then.................
Re: Small block aftermarket AC [Re: BDW] #3212873
02/11/24 08:57 PM
02/11/24 08:57 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 80ish Mopar cast intakes have the off set thermostat location on the intake. Those intakes have the EGR port, but blocking it off doesn't have that much effect on performance. Then you can just use the Mopar pulleys from the same time frame. All the 80s Mopar squad cars used that intake.
If you need to have an aftermarket intake, start building the brackets.
Re: Small block aftermarket AC [Re: poorboy] #3212879
02/11/24 09:05 PM
02/11/24 09:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
As I said, 79 and up stock intakes as well as both the Edelbrock Performer and Torker II have that offset thermostat.
Re: Small block aftermarket AC [Re: Sniper] #3212905
02/11/24 10:58 PM
02/11/24 10:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We've installed a butt load of vintage air systems with one V belt driving the compressor and never had an issue shruggy
Re: Small block aftermarket AC [Re: TJP] #3212995
02/12/24 11:43 AM
02/12/24 11:43 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
or modernize it???
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Small block aftermarket AC [Re: 69Cuda340S] #3213000
02/12/24 12:13 PM
02/12/24 12:13 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had to alter the mounting spacing and reroute the belt to get more belt wrap around the pulley, but once I did that, there was no more belt slip.
Re: Small block aftermarket AC [Re: Jerry] #3213152
02/12/24 11:38 PM
02/12/24 11:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Nice, but too wide for my 38 Ford frown It gets pretty narrow up front, A top mount compressor wont work with the 6 pack frown
Re: Small block aftermarket AC [Re: Jerry] #3213423
02/14/24 09:41 AM
02/14/24 09:41 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by Jerry
or modernize it???
That's a nice shot of the later style thermostat location.
Re: Small block aftermarket AC [Re: Sniper] #3213432
02/14/24 10:02 AM
02/14/24 10:02 AM
BDW Online content
BDW  Online Content
I seem to remember some concerns on the water neck with my install.
Maybe this pic helps?
Re: Small block aftermarket AC [Re: BDW] #3213550
02/14/24 04:38 PM
02/14/24 04:38 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Thank you all for the responses.
It looks like there will be interference between the Sanden Compressor and the thermostat housing on the standard 340 intake manifold using the aftermarket brackets.
One solution would be to replace the intake manifold with one that places the thermostat housing closer towards the driver side.
The other solution is to fabricate my own brackets which is do-able.
Thanx again for all the responses.
