Draggy data recorders, what do they record?
#3212897
02/11/24 10:22 PM
02/11/24 10:22 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Any one on here use a draggy on your cars? If so what will, do, they record? I itreid going on the website but no luck on getting any information at all Thanks in advance: Cab
Re: Draggy data recorders, what do they record?
[Re: challenger451ci]
#3212939
02/12/24 01:13 AM
02/12/24 01:13 AM
Posts: 4,672 Wichita
GY3
Wichita
A Dragy can be setup to basically give you a timeslip. It'll give 60ft, 330ft, 1/8mi ET and mph as well as 1/4mi. We've checked one at the track with a car in the deep 5's and it was pretty accurate. It can also give you 0-60 and other mph ranges if you want. Pretty cool IMHO. They also record elevation change over the run and a G meter.
[Re: Cab_Burge]
#3213011
02/12/24 01:18 PM
02/12/24 01:18 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Its NOT a data recorded past what has been stated from you last run. And they are quite accurate pretty cool little device.
#3213036
02/12/24 02:16 PM
02/12/24 02:16 PM
Cab_Burge
Oh, and I think the only way to get the data is to pair it with your "Smart" phone. That can be a challenge for us older folk...! Smart Phone, VAS is dat AKA aside I may have to step up to one of those, DANG IT
[Re: Cab_Burge]
#3213043
02/12/24 02:28 PM
02/12/24 02:28 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Here's a slip from my Mercedes. You can see the data displayed. The screen scot shows you what it will record. 0-30scrolled off the top of the page.
