Albanian mine spews hydrogen gas from “Jacuzzi” #3212474
02/10/24 01:31 PM
02/10/24 01:31 PM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
https://www.science.org/content/article/gusher-gas-deep-mine-stokes-interest-natural-hydrogen
sample quote
Hydrogen hunters are interested in ophiolites because they contain iron-rich rocks from the upper mantle. Water can react with these rocks at high temperatures and pressures to produce significant quantities of hydrogen. The flammable gas was already known to leak into the Bulqizë mine, which has experienced three major explosions, one of them deadly, since 1992.
Laurent Truche, a geochemist at Grenoble Alps University, and colleagues gained access to the mine and traced the flows to their source.
Deep in the mine, nearly 1 kilometer down, they discovered a churning pool of water, a place they would come to call “the jacuzzi.”
Truche shined his headlamp onto bubbles that turned out to be 84% hydrogen–an incredibly pure source. “I realized afterward that what I’d done in this pool was very dangerous,” he says. “The light was not explosion-proof at all, and my head was right above this bubbling spring.”
On its own, the jacuzzi was pumping out 11 tons of hydrogen per year, Truche and colleagues calculated. Based on air samples in other shafts and caverns, they believe the mine is releasing a total of 200 tons of hydrogen per year—enough to fill the Hindenburg zeppelin 10 times over. That flux is about 1000 times greater than those documented from ophiolites in other places, such as Oman, says Yashee Mathur, a graduate student in energy science and engineering at Stanford University who is studying natural hydrogen.
end quote
Obviously, time to get serious.
NASCAR and drag racing need to add hydrogen fueled engine class racing immediately.
Bud Lite should lavishly sponsor.
Re: Albanian mine spews hydrogen gas from “Jacuzzi” [Re: 360view] #3212498
02/10/24 02:36 PM
02/10/24 02:36 PM
I was hoping the automotive industry and other industries would choose Hydrogen as the next fuel for all of our I.C. engines regardless of the application from lawnmowers to large commercial aircraft up scope twocents
Re: Albanian mine spews hydrogen gas from “Jacuzzi” [Re: 360view] #3212572
02/10/24 07:07 PM
02/10/24 07:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
sample quote
end quote
So the Zeppelin contained 20 tons of Hydrogen?
That does not sound right.
Anybody want to do the math?
Assume it was under what maybe 2psi and filled 75% of the hull and provided lift at 0 to 8,000ft?
Re: Albanian mine spews hydrogen gas from “Jacuzzi” [Re: jcc] #3212677
02/11/24 06:12 AM
02/11/24 06:12 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I did a back of the envelope using a web converter and 7,062,000 ft2 of H2 is a little over 36,000 lbs so 20 tons is in the ballpark.
Re: Albanian mine spews hydrogen gas from “Jacuzzi” [Re: 360view] #3212678
02/11/24 06:54 AM
02/11/24 06:54 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Notice it is a Chromium mine.
Send me all your bumpers and auto parts that need re-plating
and a small deposit for shipping and handling (say $100,000)
and off I go to Albania.
What could possibly go wrong.....
Re: Albanian mine spews hydrogen gas from “Jacuzzi” [Re: 6PakBee] #3212722
02/11/24 11:08 AM
02/11/24 11:08 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Thank you, curious, what dimensions did you use to approximate the H2 on board cells?
Re: Albanian mine spews hydrogen gas from “Jacuzzi” [Re: jcc] #3212985
02/12/24 10:50 AM
02/12/24 10:50 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I used the capacity outlined in this Wikipedia article.
Hindenburg Statistics
