Oil Leak Detection Dye #3211817
02/08/24 03:00 AM
02/08/24 03:00 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I'm chasing an oil leak on the Road Runner (rear main, seal housing, oil pan). I was thinking of trying the oil detection dye, I've never used it so I'm not sure how successful I'll be but I thought it may be worth a shot.
Which dye have you guys had the best luck with?
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3211818
02/08/24 03:17 AM
02/08/24 03:17 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Most of the dye brands are all pretty good the most important is the intensity of the ultraviolet light. Most of the UV lights that come with the dye are not worth a darn. Search for a good UV light,
Re: Oil Leak Detection Dye [Re: A12] #3211819
02/08/24 03:24 AM
02/08/24 03:24 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This one is around $40 bucks on Amazon and others up and over $100 shock but in the long run worth getting a good one IMO.
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3211906
02/08/24 10:58 AM
02/08/24 10:58 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Do you have a good relationship with any mechanics? The dye is available separately, so all you need are the glasses and a good light as mentioned. You might just buy the dye and borrow the glasses and a good light. A good light would be the most expensive part of the proposition. Heck, a shop may do it for/with you for not much more than the cost of the components themselves which might be the way to go if this were to be your only need for the light and glasses.
The dye works really good if the area around the car is not too bright and if you have a good UV light. You don't even need to clean the suspected area before testing.
Master, again and still
Re: Oil Leak Detection Dye [Re: A12] #3212137
02/09/24 06:02 AM
02/09/24 06:02 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Rural King has a headlight with two strong UV diodes on either side, designed for tracking urine and blood drops at night, but lights up leak dye better than most of my other UV lights, except the large UV surface sanitizer from Brookstone.
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3212346
02/09/24 11:14 PM
02/09/24 11:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Don't overlook the bakc of the intake, vlave covers, cylinder heads, cam and oil galley plugs smile I brake clean the area including in side the BH until it is dry as the mojave in august.
Start the motor, let it idle till warm and check.
Next start again runt at ~ 250 RPM for 3-5 minutes, check again.
Next a short road test at lower speeds.
Finally a highway run if needed.
try some uphill downhill runs if possible.
keep us posted.
Re: Oil Leak Detection Dye [Re: TJP] #3212348
02/09/24 11:22 PM
02/09/24 11:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
"runt at 250 RPM ?? I think you meant 2,500 RPM (we knew that wink )
Re: Oil Leak Detection Dye [Re: TJP] #3212363
02/10/24 12:21 AM
02/10/24 12:21 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
keep us posted.
Thanks for the tips.
I have cleaned the back of the block with brake clean a couple of times looking for the leak. It's not coming from the intake, valve covers, oil galley plugs or cam plug. I also do not see any oil below the rear main seal or on the sides of the rear mail retainer. They only place I see it is at the very back of the oil pan. It doesn't leak while idling only when driving. In fact, if I baby it it leaks very little, if I get on it a couple of time going around the block it leaks bad. I've taken the pan/windage tray off and the oil pain gaskets looked great when I took them off. I replaced them and reinstalled everything. Still leaks rant
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3212368
02/10/24 01:33 AM
02/10/24 01:33 AM
CA
crackedback Offline
crackedback  Offline
CA
I've used foot powder spray in the areas of most likely leaks.
Re: Oil Leak Detection Dye [Re: crackedback] #3212371
02/10/24 01:58 AM
02/10/24 01:58 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I bought a cheap light and glasses combo off Amazon and saw the ac dye easily. Not sure if that shows better than one for motor oil, but cheap worked for me.
I want my fair share
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3212407
02/10/24 10:22 AM
02/10/24 10:22 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Might check that PCV valve, too.
Re: Oil Leak Detection Dye [Re: crackedback] #3212468
02/10/24 01:14 PM
02/10/24 01:14 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
When I drive it around "the block" ( 3 miles ) it leaves a 4" puddle of oil on the shop floor in 10 minutes. It's REALLY leaking.
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3212521
02/10/24 04:21 PM
02/10/24 04:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Coat both sides of a new pan gasket with Loctite 515 Gasket Eliminator (or Loctite 518 GE) and put that out of the way. I've used Loctite 515 Gasket Eliminator for decades and never a bad result.
Re: Oil Leak Detection Dye [Re: A12] #3212635
02/10/24 10:05 PM
02/10/24 10:05 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I used the Right Stuff which most folks like. I may have to give the loctite a try. I have a windage tray so I have two gaskets to worry about.
Re: Oil Leak Detection Dye [Re: A12] #3212652
02/10/24 11:14 PM
02/10/24 11:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
One has to isolate the source FIRST wink Had a customer years ago that cased a leak on a fresh resto before brig it in. 1st question was: are you sure the galley plugs are tight and sealed. Said he did them himself. After 5 pan gaskets 2 rear mains 1oil pan by him, We did the pan gasket, put rear main in, and put the original pan back on.
No change. I had thoroughly de-oiled the BH'sng etc. I put a small piece of wadded up paper towel on a set of mechanical fingers and snuck it up into the BH'sng avoiding the rear main etc. It came back down with fresh oil.
Remover the trans, bh, and flywheel while he watched. Upper R galley plug was finger tight frown . I have more stories wink but you have to diagnose before going for the "FIX"
You're comment about it leaks worse with higher RPM? make sure you're not building excess crankcase pressure wink
Keep us posted
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3212712
02/11/24 10:35 AM
02/11/24 10:35 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The Right Stuff is great! Just be careful where you use it. It bonds so well that you can damage the part that you are sealing should you ever need to take it back apart. Personally, I wouldn't use it on the pan and tray. I think you would have to damage/destroy the pan rail and tray to get it apart.
I don't have any experience with the Loctite product. Sounds interesting.
Re: Oil Leak Detection Dye [Re: TJP] #3212754
02/11/24 12:42 PM
02/11/24 12:42 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Keep us posted
I'm not sure it's the higher RPMs that make it leak but maybe the sloshing of the oil to the back of the pan. I have used a fiber optic camera between the block and flywheel and can see no oil up there. I've tried the toilet paper on long tweezers as well. The rear main and oil galley plugs are dry. I taped a diaper (paper towel) to the back the engine and the leak was where the rear main retainer met the the oil pan. runaway
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3212761
02/11/24 01:01 PM
02/11/24 01:01 PM
central il.
second 70 Offline
second 70  Offline
central il.
Might want to check and make sure your oil pan bolts aren't too long. The factory bolts are a little shorter than the ones they sell now.
Easy test is remove the bolts one at at time and add a flat washer to each then retighten. You might be pleasantly surprised to see it might have stopped the leak.
Re: Oil Leak Detection Dye [Re: VITC_GTX] #3212768
02/11/24 01:24 PM
02/11/24 01:24 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The oil pan doesn't have a small rust pit hole in it?
Re: Oil Leak Detection Dye [Re: DaveRS23] #3212775
02/11/24 01:57 PM
02/11/24 01:57 PM
Alberta
440_Offroader Offline
Alberta
The loctite 515 does work very good. It is similar to DaveRS23's post in regards to the right stuff and taking things apart. You'll need a hammer and a hammer scraper to get things apart. I have personally seen a part 515'd to an industrial engine block, that weighed 6,800lbs. Trying to lift the part off with a 10t crane, would lift the block off the floor. The part came off in 3 pieces... It's good stuff, but careful where you put it. I find it will come apart easier if it's metal on metal. If it's on a gasket, you have to pull the gasket apart, which is stronger than one would think.
