Re: 99 Dakota Fuel pressure question
[Re: Sniper]
#3210977
02/05/24 10:10 PM
02/05/24 10:10 PM
Posts: 2,730 541 slobovia
A990
541 slobovia
I am sure the FSM mentions an expected pressure and maybe even a +/-. In any case, a 15 psi fluctuation is not good. I followed the FSM and the static pressure is within specs, as is the leakdown and fuel flow test. At about 35 mph, the truck will start bucking and try to lay down. backing slightly off the throttle will calm is some. Is this a plugged fuel filter symptom?
[Re: A990]
#3211063
02/06/24 10:29 AM
02/06/24 10:29 AM
Posts: 18,415 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I am sure the FSM mentions an expected pressure and maybe even a +/-. In any case, a 15 psi fluctuation is not good. I followed the FSM and the static pressure is within specs, as is the leakdown and fuel flow test. At about 35 mph, the truck will start bucking and try to lay down. backing slightly off the throttle will calm is some. Is this a plugged fuel filter symptom? Is the fuel pressure in specs when it is acting up? You need to drive it and watch the pressure.
[Re: moparx]
#3211247
02/06/24 08:07 PM
02/06/24 08:07 PM
A990
541 slobovia
Had a 94 ram with 318 did something similar. Wide open or barley on the throttle was fine but anything in between it would buck and run terrible. I left the lights one day and had to jump start it. Ran fine for a bit. I checked the battery and connections, turns out the battery was on its way out. Swapped in a battery and problem went away. Something to check for anyway. i had a caravan that acted this way one time, and it was the battery as well. Sure enough. The battery is on its way out. It's about to turn 10 years old, so I can't complain (much) lol
