Re: modern alternator swaps for BB, highest amp at idle
[Re: jeepers007]
#32104
12/01/06 07:48 PM
12/01/06 07:48 PM
Posts: 329 N.Y.
VZCharger
N.Y.
I used the arm from a GM product when I mounted mine, figure if it was a GM alternator then a GM bracket should work . It had a large curve to it that wrapped around the alternator so I didn't need an extension. I just went to the local speed shop and looked through their catalogs 'till I found one that looked like it could work.
70 Charger blown injected BB
07 Charger Daytona Plum Crazy #389
69 Coronet ragtop
96 Ram "Garlits Edition"
88 Conquest TSi
[Re: jeepers007]
#32105
12/01/06 08:57 PM
12/01/06 08:57 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Maybe one of our resident metal workers could fab up a new arm that takes care of this issue. Should be cheap to do... Doesn't need to be anything fancy.
This thread needs to be saved in the tech section!
[Re: Von]
#32108
12/02/06 09:26 AM
12/02/06 09:26 AM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
I think the 144 housing would fit. The issue would be with the bottom bracket, maybe not on a 440, but a new bracket or a different on would be needed for the 383. Why do you need a 140a alternator anyway?
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
