Need Help Identifying Part #3210331
02/03/24 07:27 PM
02/03/24 07:27 PM
Phoenix, AZ USA
RVMopar Offline OP
RVMopar  Offline OP
Phoenix, AZ USA
I am in the process of rebuilding a distributor for a 1978 Mopar 440.
While cleaning all the components the non metallic part in the attached picture got damaged.
What is name of this part and where can I buy a new one.
Thank you
John
Re: Need Help Identifying Part [Re: RVMopar] #3210341
02/03/24 08:17 PM
02/03/24 08:17 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Is this the piece at the bottom of the distributor that takes up the vertical shaft movement slack between the main body and the retaining clip?
Sorry, hard to tell how big (physically) this part is w/o there being another part to reference it to.
Re: Need Help Identifying Part [Re: Diplomat360] #3210371
02/03/24 10:55 PM
02/03/24 10:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree it looks like one, but they are normally pinned to the shaft shruggy
Re: Need Help Identifying Part [Re: RVMopar] #3210372
02/03/24 10:57 PM
02/03/24 10:57 PM
It should have a hole in it for a drive in retaining pin that is bigger than the hole in the distributor shaft that holds that plastic spacer retainer on the distributor shaft to limit the up and down movement of that shaft, I think that is he part scope
You may try buying a small parts rebuilding kit to get that spacer and a new drive in pin, if they are still available, the other option is to get another junk distributor and rob the parts you need for yours scope wrench luck
Re: Need Help Identifying Part [Re: RVMopar] #3210403
02/04/24 05:32 AM
02/04/24 05:32 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
All of you are talking about the distributor thrust washer and collar, PN 2875731. But I think it looks larger than should be… and… without hole?
On left, the original, on the right the replacement
https://www.forbbodiesonly.com/moparforum/attachments/20220126_190025-jpg.1230955/
Re: Need Help Identifying Part [Re: NachoRT74] #3210404
02/04/24 06:13 AM
02/04/24 06:13 AM
Valencia, España
Valencia, España
But is not the thrust collar, its the spacer collar underneath the advance plate
Re: Need Help Identifying Part [Re: NachoRT74] #3210693
02/04/24 10:28 PM
02/04/24 10:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I believe Nacho nailed it 🎯👍
