Help to ID this Dodge item… #3210035
02/02/24 03:41 PM
02/02/24 03:41 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
I have this plastic emblem, and have no idea what car it is for. I was thinking grille of a ‘67 Coronet, but doesn’t seem to match up. It’s around 2”. Laying on a business card in picture. Maybe C Body? IDK. It is new, never on a car, no numbers on it.
Re: Help to ID this Dodge item… [Re: Bull1tt] #3210150
02/02/24 09:59 PM
02/02/24 09:59 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
I can tell you it's NOT a '67 coronet part. I'm thinking early 60's...
Re: Help to ID this Dodge item… [Re: nuthinbutmopar] #3210155
02/02/24 10:40 PM
02/02/24 10:40 PM
NW
hergfest Offline
hergfest  Offline
NW
I believe that's a 1965 Coronet 440 emblem. It goes on the top of the deck lid.
Re: Help to ID this Dodge item… [Re: Bull1tt] #3210161
02/02/24 11:14 PM
02/02/24 11:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Is it plastic? If so might be a steering wheel hub center . Looks to have a locating notch.
Re: Help to ID this Dodge item… [Re: hergfest] #3210164
02/02/24 11:18 PM
02/02/24 11:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up up
Re: Help to ID this Dodge item… [Re: hergfest] #3210173
02/02/24 11:51 PM
02/02/24 11:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Think you are right
Re: Help to ID this Dodge item… [Re: NITROUSN] #3210180
02/03/24 12:29 AM
02/03/24 12:29 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
That looks like it. Thought it was too small, but that looks the same. It’s plastic, and is new, never used.
Re: Help to ID this Dodge item… [Re: Bull1tt] #3210385
02/03/24 11:33 PM
02/03/24 11:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The emblem with the ring was glued to the top of the deck lids. Commonly used to close the trunk and fall off while driving down the road. They were being re-popped but not sure if they still are. If not, would be a hard to find item. The emblem for the 500 was different but the outer ring was the same. have never seen the plastic insert by itself and not sure it was offered separately. Would have to have a 65 parts book to determine. beer
