V6 vs V8 Magnum Power Steering pump bracket. #3209653
01/31/24 09:08 PM
01/31/24 09:08 PM
IMGTX Offline OP
IMGTX  Offline OP
I need a van power steering pump bracket from a 90's Magnum Engine. Local junkyard has a V6 van.
I know the truck and vans are different but are the V6 and V8 Brackets and pumps the same?
Re: V6 vs V8 Magnum Power Steering pump bracket. [Re: IMGTX] #3210001
02/02/24 01:05 PM
02/02/24 01:05 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Link says Mopar #53008859 is the same for both V6 and V8 engines in the van application. Part number #53008859.
https://www.ebay.com/itm/3052677771...Eg5GNhAMVHxmtBh19ngkmEAQYAyABEgIA2PD_BwE
Re: V6 vs V8 Magnum Power Steering pump bracket. [Re: OrangeProwler] #3210179
02/03/24 12:15 AM
02/03/24 12:15 AM
IMGTX Offline OP
IMGTX  Offline OP
Awesome.
Thank you up
