Page 4 of 4 1 2 3 4
Re: Whats the best cruising gear? [Re: ireland383] #320915
11/24/09 11:40 AM
11/24/09 11:40 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
3.55's here, I think you get the best of both worlds with this gear.
Best all around gear if you drive it often.
Re: Whats the best cruising gear? [Re: Reggie] #320916
11/24/09 12:02 PM
11/24/09 12:02 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I'm running a 3.55 in my '69 Charger with a 440, 727, 3000-3200 stall, and 295/50/15 BFG's.
@ 70 mph it's around 3200 rpm, on the back roads which are 45 mph zones it's under 2500 rpm.
I don't mind driving it on the interstate, but it does get annoying. Farthest trip I've taken was about 35 miles (70miles RT) and that's enough for me.
But the way I see it, it's not a daily driver for me anyway, just a fun car. I don't have to drive it 100 miles one way and as little cruising as I do in town, the 3.55's are suffcient.
I have an '89 Diplomat AHB that has 2.94's and it is much more relaxing to drive it on the interstate. Around town though the car really isn't the dog you think it would be, but, it has the A999 in it which I think may have a lower first gear.
If I did build another car to do it all with, I would consider the 518 swap if I had an automatic, or saving up and spending the dough for the Keisler if I had a manual.
Re: Whats the best cruising gear? [Re: patrick] #320917
11/24/09 07:19 PM
11/24/09 07:19 PM
29 inch tiers and a comp cam extreme energy 230/477
Re: Whats the best cruising gear? #320918
11/25/09 03:47 PM
11/25/09 03:47 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm on 3.55 with 255/60R15. I had 3.23 on same wheels. Got plenty happy and variation is not that BIGGER to get worried.
Both of them works for cruise, then mileage is what you will need to think. Myself I don't care the 10% mileage change ( Ok I pay US$ 3 to fill my tank on a 74 Charger, so who cares milage LOL ). I mean 10% cause that's more less the gear variation.
overall, 3.23 is the best gear setup for highway to win torque from 2s gears. For street, both works great really. If you are going down from 4s, I think 3.55 is the best to keep some of the high gears you had and FEELS you are not loosing a lot.
Re: Whats the best cruising gear? [Re: 70RT Charger] #320919
11/25/09 05:16 PM
11/25/09 05:16 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I went from 3.23 to 3.91's with 28" tall tires in the Duster and it was like night and day. LOVE it. I do a lot of freeway driving too, and it doesn't bother me a bit. Maybe my tolerance is higher than most, lol.
I also have an efficient PTC converter, which lowered my RPM by a couple hundred compared to the stock converter.
Re: Whats the best cruising gear? [Re: dOrk !] #320920
11/25/09 06:35 PM
11/25/09 06:35 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Keisler Tremec TKO, 3:54, 14's. Sweet-spot cruising all day long.
Re: Whats the best cruising gear? [Re: DennisH ] #320921
11/25/09 07:45 PM
11/25/09 07:45 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm running a 28" tall tire with 4.10 gears behind an A500 overdrive trans. Runs a tick under 2500 RPM at 70. OD was one of the best modifications I made to my car.
Re: Whats the best cruising gear? [Re: Dusted_Ya] #320922
11/25/09 11:28 PM
11/25/09 11:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It depends on how much you cruise and at what speed. I, for example like to cruise at between 75mph and 120mph which 2.73gears are ideal...
but I use 2.76 gears
I am thinking of adding an A-500 on top of it, with 550 Ft LBS it should be fun running across the wide open spaces here
Re: Whats the best cruising gear? [Re: HotRodDave] #320923
11/25/09 11:38 PM
11/25/09 11:38 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
about a 2:00 final?
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Whats the best cruising gear? [Re: MarkZ] #320924
11/26/09 07:57 AM
11/26/09 07:57 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
That's interesting.....I'm gong to be running a 2 wire 518 behind a 440 with 4:10's and 30" to 31" tire in a RC. I was wondering where my tach was going to fall at 70. Oh.....mine will be higher I guess cause I don't have a lock up.
I've ran 3.55's behind my OD 833 in my swb probably 6 to 7 years....which it ran around 2100 rpm at 70. I've also had 2.76's in the same truck twice an now it runs around 1700 at 70. I think the next gears I'm going to try will be 3.23's, because I have them to try.
I know in my 64 valiant I had 2.76 behind a regular 833 with a low first gear and it would run around 2100 rpm at 70. I can't remember what size tire I was running back then.
Moparlee
Re: Whats the best cruising gear? [Re: R70RUNNER] #320925
11/26/09 08:05 AM
11/26/09 08:05 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I have a 2.26 ration in overdrive.(3.23 axle) Very relaxed cruising at 70 MPH, about 1900 RPM and good gas mileage.
Re: Whats the best cruising gear? [Re: dmerc] #320926
11/26/09 11:39 AM
11/26/09 11:39 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'm running a 518od and 3.91 gears with a 28" tire at 2200rpm at 70.
Re: Whats the best cruising gear? [Re: stumpy] #320927
11/26/09 11:54 AM
11/26/09 11:54 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Well . . it certainly all depends what you use your car for . . . in my 74 Duster360 (stock), before going to Carlisle years ago, I swapped out the 8.25" rear end (complete) that had 3.55:1 gears, for another that was 2.45:1 gears !!! Yes, that high . . . with the 360, 727auto, 235/60/14 tires, cruising 70mph = 2500rpm !
With the torquey 360, it has no problem spinning the right rear (yeah a one legger), and love the passing power on the highway !!! Not to mention getting 22mpg @ 70mph !!!!
As I have always said, you have to build the car for you . . .for what you want to do. I like driving LONG distances to car shows, not being a drag racer or street fighter. So the car works for me !! Course I miss my big ole C Body for long distance cruising . . . .
Just my
Cheer
Mark
A12rag
Re: Whats the best cruising gear? [Re: stumpy] #320928
11/26/09 12:17 PM
11/26/09 12:17 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Stumpy, is yours a 3 wire?
Moparlee
Re: Whats the best cruising gear? [Re: Robbins] #320929
11/26/09 01:14 PM
11/26/09 01:14 PM
PA
P
plumcrazycuda Offline
P
PA
I had 3.23 to 4.30 in my purple car over the years. At first you think you are going to drive it a lot,but now if I put 500 miles a year on it its a lot. I ended up putting a 4.10 Dana in it and love it. My blue car has 3.55 in it,but I drive it more,about 2000 miles a year. If I ever get the 70 done it going to have a 3.54 Dana in it.Because thats what I have for it. If you are going to drive a lot,2500 miles or more then go with 3.23,but I bet you will end up changing to 4.10 because these old car do alot of sitting and 4.10 are a lot of fun on the street. Just my
Re: Whats the best cruising gear? [Re: DennisH ] #320930
11/26/09 02:37 PM
11/26/09 02:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Keisler TKO / 354 DANA.
Nice combo.
.......My Daytona runs a Keisler TKO 600 5spd, .64 OD....27" tire 275/60/15,..4:10 Dana.....awesome on the streets with 4:10's...or crusing on the highway in 5th at 80MPH@ 2200-2400 RPM,...with a top speed of 140-150 MPH @ 5700 RPM....your best investment is an overdrive transmission rather than a compromise in gearing
Re: Whats the best cruising gear? [Re: Robbins] #320931
11/26/09 06:24 PM
11/26/09 06:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes it is. The switches I used give me a lock up at 50 and od at 55. I also have an on-off switch hooked up to the vacuum switch that kills both.
Re: Whats the best cruising gear? [Re: stumpy] #320932
11/27/09 12:01 AM
11/27/09 12:01 AM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
With the tourque of a True 10:1 + 440 c.i. or bigger ~28" tire the 3.23s are a very good choice.You can still get it out on the interstate. And roast the tires around town at will. And no overdrive needed for 140+ top end!
Re: Whats the best cruising gear? [Re: stumpy] #320933
11/27/09 01:45 AM
11/27/09 01:45 AM
Indiana
P
Pentastar440 Offline
P
Indiana
With an A-518 doesn't it downshift out of overdrive when vacuum goes to zero ? If so how do you go 'full-throttle' while in overdrive ?? Will the transmission even go into overdrive while under full throttle ?
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Whats the best cruising gear? [Re: Pentastar440] #320934
11/27/09 11:24 AM
11/27/09 11:24 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you stomp the gas it will come out of OD but if you ease into it no problem.
Page 4 of 4 1 2 3 4
