Is QA1 front suspension for 1968-1970 B Body any good?
#3208993
01/29/24 01:53 PM
01/29/24 01:53 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I was planning on buying a QA1 front k member suspension kit for my 1968 Charger. Anybody here have any experience with this rack and pinion style front suspension kit? I usually just upgrade the suspension to bigger torsion bars, big sway bars and aftermarket steering box and other stuff. I am wanting to try something different this time around and see if the handling will be better.
Re: Is QA1 front suspension for 1968-1970 B Body any good?
[Re: Blakcharger440]
#3209120
01/29/24 11:58 PM
01/29/24 11:58 PM
Posts: 31,050 Oregon
AndyF
I was planning on buying a QA1 front k member suspension kit for my 1968 Charger. Anybody here have any experience with this rack and pinion style front suspension kit? I usually just upgrade the suspension to bigger torsion bars, big sway bars and aftermarket steering box and other stuff. I am wanting to try something different this time around and see if the handling will be better. This is what I'd do. Firm Feel upper arms, Koni shocks, big torsion bars, big anti-sway bar, big brakes, 17x8 rim with good tires. I'm pretty sure this will cost less and work better than the kit you're asking about.
#3209128
01/30/24 12:33 AM
01/30/24 12:33 AM
PasiR
I was planning on buying a QA1 front k member suspension kit for my 1968 Charger. Anybody here have any experience with this rack and pinion style front suspension kit? I usually just upgrade the suspension to bigger torsion bars, big sway bars and aftermarket steering box and other stuff. I am wanting to try something different this time around and see if the handling will be better. If you want better handling, contact Firm Feel Inc.
[Re: ThermoQuad]
#3209459
01/31/24 12:23 PM
01/31/24 12:23 PM
Posts: 19,470 north of coder
moparx
i finally installed frame connectors on my 69 charger last year, just using square 2" tube because i didn't want to cut the floor pan. what a difference that made ! i also built a 1 3/4" square tube framework reinforcing the bottom of the core support. still using the factory 15/16" sway bar. this year i plan on installing torque boxes.
