Ignition contact point sets: CH14V vs CH15V
#3208929
01/29/24 12:46 AM
01/29/24 12:46 AM
Posts: 203 Alabama
David1971
Alabama
I searched the web to find the application for these two part numbers and they both appear to be for Chrysler 6 cylinder and V8's, 1962 - 72, but there is a difference in spring tension. When would you choose one over the other?
Thanks, David
Re: Ignition contact point sets: CH14V vs CH15V
[Re: David1971]
#3208981
01/29/24 12:22 PM
01/29/24 12:22 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I searched the web to find the application for these two part numbers and they both appear to be for Chrysler V6's and V8's, 1962 - 72, but there is a difference in spring tension. When would you choose one over the other?
Thanks, David V6 62 - 72 ????? Hard to find , if you need them by them both , as sniper mentioned , new stuff sucks compared to the old.
[Re: David1971]
#3209013
01/29/24 03:13 PM
01/29/24 03:13 PM
Posts: 12,097 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I assume the 'V' means vented points. That is a good thing for temp and overall life. But also means slightly less surface area to contact. When you get the points, check to make sure that the contact areas are square to each other. Fairly often, even back then, the mating surfaces would not be in good alignment which means a smaller contact area, which would speed up the maintenance cycle. We always used Sorensen ignition parts back then. They actually had cross vented points. They were the longest lasting points I have ever seen. But that was a long, long time ago and I am not even sure Sorensen is around any more. Let alone being the same quality even if they were. If you don't need the extra spring tension for higher RPM stability, the lighter spring will usually require less frequent adjustment due to less pressure on the rubbing block. Back in the day, if everything was in spec, it was typical to go well over 10,000 miles before an adjustment was needed on daily driver stuff. And given an occasional check with a dwell meter, I have seen 15,000 miles between adjustments. Or do like most did back then, wait until it starts acting up before you pop the hood to see what's going on.
Master, again and still
[Re: Sniper]
#3209058
01/29/24 07:47 PM
01/29/24 07:47 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
V6?? fits all mopars 1961-1972 single point distributor , higher spring tension for high rpm use
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3209100
01/29/24 10:31 PM
01/29/24 10:31 PM
Posts: 203 Alabama
David1971
Alabama
V6?? fits all mopars 1961-1972 single point distributor , higher spring tension for high rpm use Oops! Didn't mean to put V6. I edited that part of my post. Should read 6 cylinder. David
[Re: David1971]
#3209153
01/30/24 09:40 AM
01/30/24 09:40 AM
JohnRR
U.S.S.A.
V6?? fits all mopars 1961-1972 single point distributor , higher spring tension for high rpm use Oops! Didn't mean to put V6. I edited that part of my post. Should read 6 cylinder. David But it can't be for all as your edit shows , small block and big block points are different, ... don't know about /6 .... , rotation of the distributor is different so you can't interchange . Make sure you get the right ones for your engine application.
[Re: JohnRR]
#3209161
01/30/24 10:19 AM
01/30/24 10:19 AM
Posts: 1,326 VA
dragon slayer
VA
V6?? fits all mopars 1961-1972 single point distributor , higher spring tension for high rpm use Oops! Didn't mean to put V6. I edited that part of my post. Should read 6 cylinder. David But it can't be for all as your edit shows , small block and big block points are different, ... don't know about /6 .... , rotation of the distributor is different so you can't interchange . Make sure you get the right ones for your engine application. Not true for Single point. Parts book calls out the same single point contact set regardless of engine type. Dual Points are different.
[Re: dragon slayer]
#3209175
01/30/24 11:05 AM
01/30/24 11:05 AM
JohnRR
U.S.S.A.
V6?? fits all mopars 1961-1972 single point distributor , higher spring tension for high rpm use Oops! Didn't mean to put V6. I edited that part of my post. Should read 6 cylinder. David But it can't be for all as your edit shows , small block and big block points are different, ... don't know about /6 .... , rotation of the distributor is different so you can't interchange . Make sure you get the right ones for your engine application. Not true for Single point. Parts book calls out the same single point contact set regardless of engine type. Dual Points are different. Ok , my bad I was thinking dual point because my 383 Dart has dual point ... carry on
