Re: Super stock spring question
[Re: cudaman1969]
#3208906
01/28/24 10:48 PM
01/28/24 10:48 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
, I would just use the springs but Dana has no pinion snubber, could make something I guess. Anyway what’s the opinion? Should't need a snubber with SS springs.
[Re: GomangoCuda]
#3208933
01/29/24 12:59 AM
01/29/24 12:59 AM
Posts: 43,300 Bend,OR USA
Cab_Burge
, I would just use the springs but Dana has no pinion snubber, could make something I guess. Anyway what’s the opinion? Should't need a snubber with SS springs. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Which part number SS springs do you have and what car, transmission type and weight are you wanting to use them on? The SS springs should make the rear of the car go up under acceleration causing more weight to help push the rear tires into pavement a lot harder and better ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Cab_Burge]
#3208943
01/29/24 01:56 AM
01/29/24 01:56 AM
Posts: 8,346 fredericksburg,va
cudaman1969
fredericksburg,va
, I would just use the springs but Dana has no pinion snubber, could make something I guess. Anyway what’s the opinion? Should't need a snubber with SS springs. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Which part number SS springs do you have and what car, transmission type and weight are you wanting to use them on? The SS springs should make the rear of the car go up under acceleration causing more weight to help push the rear tires into pavement a lot harder and better Springs are 002 003, 71 Duster Stock class 340 auto. Ive used these springs on a-body’s and b-body’s before but just by themselves. I’ve always had the snubber slightly off the floor. My goal is to leave like ladder bars or 4 link instead of the housing wrapping up like a spring losing 60 and ET.
[Re: cudaman1969]
#3208948
01/29/24 06:38 AM
01/29/24 06:38 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Caltracs and superstock springs are both designed to add rise to the rear, so you will have a hard time controlling extension (jounce) unless you have a real good shock. I've seen folk try that combo and they've been disappointed with the results. My advice would be to use the S/S springs on their own or sell them and get the correct Calvert monoleafs for your intended application. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3208951
01/29/24 08:09 AM
01/29/24 08:09 AM
Posts: 4,704 Wichita
GY3
Wichita
We tried it with 456/457 springs. Did not work at all! Installed split mono springs and it works perfect!
[Re: cudaman1969]
#3209029
01/29/24 04:14 PM
01/29/24 04:14 PM
Cab_Burge
[Re: A727Tflite]
#3209049
01/29/24 06:54 PM
01/29/24 06:54 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I ran S/S springs on my 68 Dart for years , it actually ran its best e.t. at 10.40 and best 60 ft 1.40 ( foot braking ) with them . When I went to Cal Tracs and mono leafs my 60 fts were not quite as good but they were more consistent . Currently I run on a throttle stop to run 11.50 : 60 fts are 1.48-1.52 depending on the track. Car is 3150 lbs with me in it , 410 inch small block, 904 , 4900 stall 8 inch converter , 4.30 rear , runs 10.80s off the stop
[Re: A727Tflite]
#3209057
01/29/24 07:47 PM
01/29/24 07:47 PM
cudaman1969
fredericksburg,va
The 002/003 were first released on the 68 Hemi A bodies - both 4 speed and auto.
The main leafs on 002/003’s are the thickest of all the SS springs. I do have a set that has thicker leafs than the 02-03s, NASCAR springs, same thickness as 65 AFX springs, but the N springs sit the car too low, (one side the main is flat, no arch), tires to far up in the wells, might try to re-arch them to match pass side. Reason I’m thinking S/S springs IS the car will still rotate from engine torque, rear housing will rotate for same reason, that’s why the bias. IMO
[Re: Cab_Burge]
#3209061
01/29/24 07:59 PM
01/29/24 07:59 PM
Posts: 1,612 westerly, ri. usa
440lebaron
westerly, ri. usa
either s/s springs or caltracs, not both, can make s/s springs same leaf/length, 4/5 leafs, caltrac will say not to use
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3209066
01/29/24 08:15 PM
01/29/24 08:15 PM
cudaman1969
fredericksburg,va
I’m looking to make the front segment stiff and not wrap up, remember the ladder-link setup? Very limited what we can do, just bolt on stuff
[Re: cudaman1969]
#3209135
01/30/24 03:16 AM
01/30/24 03:16 AM
Cab_Burge
[Re: B1Frank]
#3209207
01/30/24 01:19 PM
01/30/24 01:19 PM
Posts: 5,895 Florida
Locomotion
Remember that you have to make the front suspension work with the rear suspension for best results. Too soft or too stiff front shocks can negate any adjustments you make to the rear. But overall, I had best results by using the basic suspension parts (i.e.: SS springs, 6 cyl torsion bars, frames tied, etc.) but tuning the suspension action with different shocks or different shock adjustments on adjustable shocks. i.e.: Rancho 9 way on the rear and QA1 single adjustable drag shocks on the front.) As mentioned earlier (I think.)...I has SS springs & Mopar manual trans drag shocks on my Dart Sport and still had wheel hop under certain conditions. Switched to much stiffer Ranchos and the problem went away. Same track, same conditions.....it may have spun sometimes, but never wheel hopped again. You can have all the "rise" you can get in the rear, but that won't help traction in all cases, especially with modern high stall converters, better traction through tire and track improvements, etc. The shock ultimately controls separation and compression. The harder a car leaves, the more the rear suspension has to be controlled by stiffer shocks.
[Re: Locomotion]
#3209261
01/30/24 05:56 PM
01/30/24 05:56 PM
cudaman1969
fredericksburg,va
This is some of the info I’m looking for, thanks to all so far. Wanting to know what happens if using the two together, yes I have the rancho shocks plus the adjustable fronts, also no factory rubber bushings in front, lca, uca and strut, very free moving. 9” radials 5.13 gears 4600 dynamic vert low gear 904. Frame tied and cm cage, front to back
