Page 1 of 4 1 2 3 4
Whats the best cruising gear? #320855
05/17/09 08:22 PM
05/17/09 08:22 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Im getting closer to start restoring my rear end and I plan on doing alot of cruising.I plan on making small trips,hitting the interstate and doing local cruise ins.My setup that I have is a mild 440-4-speed-391 gears and when I was driving it before it really tached up there when I hit the interstate.I thought about the 323s,then I thought that maybe to high.Just want some opinions what would be the best gear to go with.Thanks,Chris
Re: Whats the best cruising gear? [Re: 70RT Charger] #320856
05/17/09 08:25 PM
05/17/09 08:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Depends on your tire diameter. 3:55's are a good compromise and it's what I usually run.
Re: Whats the best cruising gear? [Re: 70RT Charger] #320857
05/17/09 08:25 PM
05/17/09 08:25 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
For cruising I like 3.23s.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: Whats the best cruising gear? [Re: 70RT Charger] #320858
05/17/09 08:42 PM
05/17/09 08:42 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
THINK about it .... how often do you use a "cruiser" or streeter for stop-light/drag-strip action ?
NOT MUCH.
So I now have ...in a light-weight(for a B-body) car ..with a torquey 440 .... a 2.76 gear.
I drive-it ... and LOVE IT.
SURE ...it does not 60-foot like a 4.56 gear ... but for a streeter... you will LOVE the cruise-speed and MPG
Re: Whats the best cruising gear? [Re: Neil] #320859
05/17/09 08:46 PM
05/17/09 08:46 PM
Kirkland, Washington
Pacnorthcuda Offline
EVERY gear is a compromise in one way or another. I run 28 inch rears. 3.55 for me.
Re: Whats the best cruising gear? [Re: dOrk !] #320860
05/17/09 08:51 PM
05/17/09 08:51 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Get an overdrive transmission. Best of both worlds. Why compromise? If you have a 4-gear, passon makes an o/d gearset or you could do a 70's/80's o/d 833 for cheap. If that doesn't sound appealing, play with this calculator:
http://vexer.com/68rt/speed.html
I've got 3.55's and a 727 and it's basically 3000rpm at 65mph. Livable but I don't like to see my motor revving that high needlessly so I have an overdrive trans in the garage waiting for me to get to it.
Re: Whats the best cruising gear? [Re: DaytonaTurbo] #320861
05/17/09 08:53 PM
05/17/09 08:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
3.73 w/ a 275/60/15... best of both worlds. 3.55's are ok but in heavy car they can drag some out of the hole.
Coming soon!!!!
Re: Whats the best cruising gear? [Re: Mr.Yuck] #320862
05/17/09 08:58 PM
05/17/09 08:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
For daily driving and the Eway I'd go with 3.23s.
Re: Whats the best cruising gear? [Re: 70RT Charger] #320863
05/17/09 08:58 PM
05/17/09 08:58 PM
Eastern ohio
Alexdodge Offline
Alexdodge  Offline
Eastern ohio
I took out the 3:55 out of the 64 and put in 2.93 posi. With the 440 its great. Only used for touring and cruising.It still has a powerful top end!
Alex in Ohio
Will be taking it to Tennessee this weekend. All four lane driving for about 6 hours.
Re: Whats the best cruising gear? [Re: 70RT Charger] #320864
05/17/09 09:02 PM
05/17/09 09:02 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I like 3.55
Re: Whats the best cruising gear? [Re: Alexdodge] #320865
05/17/09 09:03 PM
05/17/09 09:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Lots of freeway 2.76 or 2.94... Best all around 3.23, around town 3.55 or 3.73.. Hotrod 3.91 or more.. Build a stroker & 2.76's can still put you in the 12's...
Re: Whats the best cruising gear? [Re: 1_WILD_RT] #320866
05/17/09 09:24 PM
05/17/09 09:24 PM
Connecticut, USA
sixty7gtx Offline
sixty7gtx  Offline
Connecticut, USA
3.23 for my charger RT, 3.55 for the GTX. any taller may be too much for long distace?
1967 Plymouth GTX,
1968 HEMI, 4 Spd. Super Bee,
2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: Whats the best cruising gear? [Re: sixty7gtx] #320867
05/17/09 09:25 PM
05/17/09 09:25 PM
Connecticut, USA
sixty7gtx Offline
sixty7gtx  Offline
Connecticut, USA
charger RT
1967 Plymouth GTX,
Re: Whats the best cruising gear? [Re: sixty7gtx] #320868
05/17/09 10:13 PM
05/17/09 10:13 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
with the 4 speed I would recommend the 3.23, if you run taller (like 2.76) with the torquey 440 and the 4 speed in a heavy car the clutch will not be happy at all.
I run a 275-70-15 on my stock 440 68 Charger and it is fine on the highway with excellent off the line.
I also have a 68 300 with a stock 440 and 2.76 and it is a highway monster, but off the line is not so happy...
Re: Whats the best cruising gear? [Re: sthemi] #320869
05/17/09 11:20 PM
05/17/09 11:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This might help you figure out what you need. http://vexer.com/68rt/speed.html
Re: Whats the best cruising gear? [Re: DaytonaTurbo] #320870
05/17/09 11:23 PM
05/17/09 11:23 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Overdrives are totally the way to go. A Gearvendor is pricey, but It's paying for itself each time I drive the car. 4.30's and a Gearvendor behind my 904 with 25.7" tires puts me at 70 mph @ 3100 rpm (plus or minus a mile per hour or two). I just drove my car on the first small road trip yesterday after the GV install (about 1.5 hours each way). Man it was nice. In overdrive, I have the equivalent of a 3.35 gear.
Re: Whats the best cruising gear? [Re: 68Bullit] #320871
05/17/09 11:58 PM
05/17/09 11:58 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Keisler TKO / 354 DANA.
Nice combo.
Re: Whats the best cruising gear? [Re: DennisH ] #320872
05/18/09 12:13 AM
05/18/09 12:13 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
3.23 has been the best for me. I drive a ton and those help a bunch.
On the eastern KY two lanes I don't think you will want a 2.94 or higher gear. I run into enough traffic over there that it would cause some extra shifting as the 3.23 almost does sometimes.
If you are running a stock size tire the 3.23 will turn plenty of RPMs on the interstate. A 3.55 would be getting close to unbearable for me. But if you find a deal on one I wouldn't turn it down, I know parts in our part of the world can be hard to come by and new stuff is spendy.
I want my fair share
Re: Whats the best cruising gear? [Re: SomeCarGuy] #320873
05/18/09 12:19 AM
05/18/09 12:19 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
It depends on how much you cruise and at what speed. I, for example like to cruise at between 75mph and 120mph which 2.73gears are ideal...
Re: Whats the best cruising gear? [Re: DaytonaTurbo] #320874
05/18/09 12:44 AM
05/18/09 12:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Exactly,......I enjoy 4:10 gears on the street,.......and with my Keisler 5spd TKO .64 OD they equate to 2.64's in 5th gear cruising on the interstate,......running a 275/60/15 tire, MPG can range as high as 22 MPG, and MPH in the 140/150 range with a 440/6, with 4:10's.......if "originality" is your thing,.....put a Passon transmission in it?, why compromise on rear gear sets, or desired tire size?
Page 1 of 4 1 2 3 4
