Re: 7.75x14" blue streak repro tires choices?
[Re: autoxcuda]
#3203418
01/09/24 01:34 PM
01/09/24 01:34 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
Drivers side markings on front eyelet of leaf spring
Looks like medium or pastel green on inside and white on outer side.
Anyone else find this on 66 Hemi Auto's?
Isn't there a list of leaf spring markings out there?
[Re: gtx6970]
#3203728
01/10/24 11:13 PM
01/10/24 11:13 PM
autoxcuda
So Cal
Any idea if there is a Gasket under the hood ornament? Is there just the one data tag under hood? No hemi fender tag correct ? No gasket Only one tag
Re: Now: 66 Hemi Satellite survivor
[Re: mattsmopars]
#3207209
01/22/24 02:53 PM
01/22/24 02:53 PM
autoxcuda
So Cal
If you have an opportunity please take some pictures of the original wheels. The stamping around the valve stem , area around the lug bolt holes, and stamping/ manufacturer inside the hoop if you pull the tires. Thank you, Matt Will do. What does everyone this of these numbers on the tail pipe tips? K-2781286 Factory or aftermarket?
[Re: gtx6970]
#3208140
01/25/24 05:57 PM
01/25/24 05:57 PM
Posts: 5,308 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Just a beautiful Satellite! I had a large size poster of a collage of Hemi Mopar's when I was in high school back in the late 70's- early 80's. This (Pete Haldiman) Satellite was one of the cars in that poster! Along with Marvin Hughes' '64 Hemi Dodge, and a handful of other Hemi cars. I also am sure I had a copy of that Car Craft magazine too, with the SuperCar Shootout. Wish I still had them. Good luck with that Plymouth!
Plymouth Makes It!
[Re: RoadRunnerLuva]
#3208206
01/26/24 01:13 AM
01/26/24 01:13 AM
autoxcuda
So Cal
Just a beautiful Satellite! I had a large size poster of a collage of Hemi Mopar's when I was in high school back in the late 70's- early 80's. This (Pete Haldiman) Satellite was one of the cars in that poster! Along with Marvin Hughes' '64 Hemi Dodge, and a handful of other Hemi cars. I also am sure I had a copy of that Car Craft magazine too, with the SuperCar Shootout. Wish I still had them. Good luck with that Plymouth! Actually that's a gold Hemi Bel II is a convertible (I believe Hughes’) Pete’s car was the 69 Hemi 500 with dealer vinyl top. Sold to C500's dad. And Radke's Hemi Daytona replaced it (now Lembeck's in F6) The poster was from Automobile Quarterly. AQ used pictures of Pete’s 500 for an article on Wing Cars. I bought this poster never used about 5 or so years ago at a Spring Fling. From my garage wall right now:
[Re: autoxcuda]
#3208322
01/26/24 04:18 PM
01/26/24 04:18 PM
RoadRunnerLuva
Land 'O Lakes
Yup, that's the poster! My memory is fuzzy, sorry, I just remembered a gold Plymouth in that poster, didn't remember it being a convertible...it been over forty years, since I last saw it. Regardless, you have a gorgeous car, I hope you get many years of happiness with it.
Plymouth Makes It!
[Re: gtx6970]
#3208405
01/27/24 12:38 AM
01/27/24 12:38 AM
autoxcuda
So Cal
Car on upper right hand corner is ?????
The Belv conv was Marvin Hughes at the time ,, same for the 64 car
Same 66 Belv vert today Says Carl Dwiggins on the silver/red 66 Hemi Satellite. Same owner for the dark blue/black 68 Hemi RR under it.
[Re: srt]
#3219540
03/10/24 02:43 PM
03/10/24 02:43 PM
autoxcuda
So Cal
Carbs done last night from me just rebuilding and cleaning the grime of them…
[Re: autoxcuda]
#3219583
03/10/24 05:29 PM
03/10/24 05:29 PM
Posts: 21,406 It's a dry heat
gtx6970
It's a dry heat
Nice, what did you clean them in / with
[Re: gtx6970]
#3219588
03/10/24 05:52 PM
03/10/24 05:52 PM
autoxcuda
So Cal
Nice, what did you clean them in / with Just brake clean and brass wire brushes. Lightly go over with steel wire brushes as last resort. And repetition. Wenol polish on the brass. And some wenol on stains in corners with a Q-tip and/or stiff plastic brush. I did notice the special carb nuts. They have a slightly raised then machined flat surface to the ends.
[Re: autoxcuda]
#3219735
03/11/24 01:16 PM
03/11/24 01:16 PM
Posts: 8,240 fredericksburg,va
cudaman1969
fredericksburg,va
Same 66 Belv vert today Says Carl Dwiggins on the silver/red 66 Hemi Satellite. Same owner for the dark blue/black 68 Hemi RR under it. Now I know what my silver car will look like finished (black interior) Oops, that pic is a Satellite mines a Bel
