Re: TTI headers on small block
[Re: dvw]
#3205393
01/16/24 10:31 PM
01/16/24 10:31 PM
Posts: 15,489 Omaha Ne
TJP
Omaha Ne
Though this s n E body I believe they are the same prt number from TTI. Doug ROOM to get the starter out? THAT's JUST WRONG!!! π€£π―
[Re: dvw]
#3205483
01/17/24 08:14 AM
01/17/24 08:14 AM
Posts: 5,895 Florida
Locomotion
Though this s n E body I believe they are the same prt number from TTI. Doug If I remember correctly, E and A-body headers are the same on the passenger side. Driver's side A-body has a detached #7 tube that goes around the torsion bar. E are the same as F-body. Mini-starter removal isn't bad with any, just may take some steering movement while wiggling it in & out.
[Re: TJP]
#3205497
01/17/24 09:24 AM
01/17/24 09:24 AM
Posts: 9,871 MI, usa
dvw
MI, usa
Though this s n E body I believe they are the same prt number from TTI. Doug ROOM to get the starter out? THAT's JUST WRONG!!! π€£π― These were the easiest headers i ever installed. Didn't even use header bolts. Standard bolts fit. TT shows the same part for A body and E body. https://www.ttiexhaust.com/TTi340.htmDoug
[Re: TJP]
#3205515
01/17/24 10:32 AM
01/17/24 10:32 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Though this s n E body I believe they are the same prt number from TTI. Doug ROOM to get the starter out? THAT's JUST WRONG!!! π€£π― And you don't have to take the steering linkage apart to install/remove he headers ... what the heck is wrong with these people ???
[Re: dvw]
#3205584
01/17/24 01:04 PM
01/17/24 01:04 PM
Locomotion
Though this s n E body I believe they are the same prt number from TTI. Doug ROOM to get the starter out? THAT's JUST WRONG!!! π€£π― These were the easiest headers i ever installed. Didn't even use header bolts. Standard bolts fit. TT shows the same part for A body and E body. https://www.ttiexhaust.com/TTi340.htmDoug TTI Part #'s & applications.It's basically A-body and then all the rest.
Re: TTI headers on small block>
[Re: Locomotion]
#3205737
01/17/24 07:42 PM
01/17/24 07:42 PM
dvw
MI, usa
Though this s n E body I believe they are the same prt number from TTI. Doug ROOM to get the starter out? THAT's JUST WRONG!!! π€£π― These were the easiest headers i ever installed. Didn't even use header bolts. Standard bolts fit. TT shows the same part for A body and E body. https://www.ttiexhaust.com/TTi340.htmDoug TTI Part #'s & applications.It's basically A-body and then all the rest. The link I posted shows the same prt number. Doug
[Re: JohnRR]
#3205795
01/17/24 11:45 PM
01/17/24 11:45 PM
TJP
Omaha Ne
Though this s n E body I believe they are the same prt number from TTI. Doug ROOM to get the starter out? THAT's JUST WRONG!!! π€£π― And you don't have to take the steering linkage apart to install/remove he headers ... what the heck is wrong with these people ??? π― no reason to swear, drink beer, smoke cigarettes - - - WTH are they thinking? has to be the democrats and liberals π€£
[Re: TJP]
#3205802
01/18/24 12:18 AM
01/18/24 12:18 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
TTI headers and TTI 2 1/2 exhaust on my '69 A Body. Mufflers are Dynomax Ultra Flo but pipes are TTI.
[Re: moparx]
#3206380
01/19/24 11:09 PM
01/19/24 11:09 PM
TJP
Omaha Ne
I'm 6-1/2 years clean on the alcohol and tobacco congratulations ! keep up the good work ! i haven't had a smoke since the 1985/86ish time period, although i must keep up the "family tradition" of beer drinkers with an occasional one or three........ Congrats to you as well My issue is if I have ONE of either, it will eventually lead to another, then two, then three until I wind up back where I was. I've learned that the only way I can control both is not to have either I learned this after quitting both several times. 4+ weeks in an induced coma followed by 4 + weeks of rehab was the perfect time to walk away from both.
[Re: jst19600]
#3208424
01/27/24 08:38 AM
01/27/24 08:38 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
What about Dougs D453 headers for small block,does anyone know if they angle in? Having had both TTIβs and Dougs on A body small blocks, I much prefer the fit of the Dougs, and they make good power.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30βs 1/4 1.41 best 60 foot 6.56 at 104.17
