TTI headers on small block #3205314
01/16/24 05:52 PM
01/16/24 05:52 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
TTI headers for small block 67-76 A body.Do the header collectors exit angled in towards the drive shaft or do they run parrallel with the frame?The pictures ive seen look like the are angled.
Re: TTI headers on small block [Re: jst19600] #3205392
01/16/24 10:23 PM
01/16/24 10:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Though this s n E body I believe they are the same prt number from TTI.
Doug
Re: TTI headers on small block [Re: dvw] #3205393
01/16/24 10:31 PM
01/16/24 10:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Doug
ROOM to get the starter out? THAT's JUST WRONG!!! 🀣🎯
Re: TTI headers on small block [Re: jst19600] #3205394
01/16/24 10:31 PM
01/16/24 10:31 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I have both small and big block TTI A-body headers and they both angle inward.
Re: TTI headers on small block [Re: dvw] #3205483
01/17/24 08:14 AM
01/17/24 08:14 AM
Locomotion Offline
Locomotion  Offline
Doug
If I remember correctly, E and A-body headers are the same on the passenger side. Driver's side A-body has a detached #7 tube that goes around the torsion bar. E are the same as F-body. Mini-starter removal isn't bad with any, just may take some steering movement while wiggling it in & out.
Re: TTI headers on small block [Re: TJP] #3205497
01/17/24 09:24 AM
01/17/24 09:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
These were the easiest headers i ever installed. Didn't even use header bolts. Standard bolts fit. TT shows the same part for A body and E body.
https://www.ttiexhaust.com/TTi340.htm
Doug
Re: TTI headers on small block [Re: TJP] #3205515
01/17/24 10:32 AM
01/17/24 10:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doug
And you don't have to take the steering linkage apart to install/remove he headers ... what the heck is wrong with these people ???
Re: TTI headers on small block [Re: dvw] #3205584
01/17/24 01:04 PM
01/17/24 01:04 PM
Locomotion Offline
Locomotion  Offline
Doug
Doug
TTI Part #'s & applications.
It's basically A-body and then all the rest.
Re: TTI headers on small block> [Re: Locomotion] #3205737
01/17/24 07:42 PM
01/17/24 07:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Doug
The link I posted shows the same prt number.
Doug
Re: TTI headers on small block [Re: JohnRR] #3205795
01/17/24 11:45 PM
01/17/24 11:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Doug
🎯 iagree
no reason to swear, drink beer, smoke cigarettes - - - WTH are they thinking? has to be the democrats and liberals stirthepot🀣
Re: TTI headers on small block [Re: TJP] #3205802
01/18/24 12:18 AM
01/18/24 12:18 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
TTI headers and TTI 2 1/2 exhaust on my '69 A Body. Mufflers are Dynomax Ultra Flo but pipes are TTI.
Re: TTI headers on small block [Re: TJP] #3205909
01/18/24 03:08 PM
01/18/24 03:08 PM
moparx Offline
moparx  Offline
i just like to drink and swear, in no particular order, for the fun of it ! laugh2 panic rant realcrazy punkrocka
unfortunately, i haven't smoked in years, unless one counts the times smoke comes out my ears due to "reasons" beyond my control........... biggrin
beer
Re: TTI headers on small block [Re: moparx] #3206063
01/18/24 11:17 PM
01/18/24 11:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I'm 6-1/2 years clean on the alcohol and tobacco, other types of smoke can emit from various body cavities for various reasons πŸ™„πŸ€£πŸ’¨
Re: TTI headers on small block [Re: TJP] #3206092
01/19/24 05:42 AM
01/19/24 05:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If you eat a high fiber diet,
yeast in your gut will ferment 2 to four ounces of ethanol
that goes directly into your blood a little at a time over 24 hours.
By going directly into your blood this alcohol does not go through the stomach where it could be chemically changed to the addictive drug acetaldehyde.
Nature gave you your own beer making equipment that makes ethanol that is not subject to taxes.
Mother Nature - the best Moonshiner....
Re: TTI headers on small block [Re: TJP] #3206219
01/19/24 02:32 PM
01/19/24 02:32 PM
moparx Offline
moparx  Offline
congratulations ! up bow
keep up the good work !
i haven't had a smoke since the 1985/86ish time period, although i must keep up the "family tradition" of beer drinkers with an occasional one or three........ biggrin
beer
Re: TTI headers on small block [Re: moparx] #3206380
01/19/24 11:09 PM
01/19/24 11:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
Congrats to you as well wink My issue is if I have ONE of either, it will eventually lead to another, then two, then three until I wind up back where I was. I've learned that the only way I can control both is not to have either frown I learned this after quitting both several times. 4+ weeks in an induced coma followed by 4 + weeks of rehab was the perfect time to walk away from both. up
Re: TTI headers on small block [Re: TJP] #3206540
01/20/24 03:29 PM
01/20/24 03:29 PM
moparx Offline
moparx  Offline
beer
eek
glad you are still here after that mess !
beer
Re: TTI headers on small block [Re: moparx] #3208080
01/25/24 01:06 PM
01/25/24 01:06 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
What about Dougs D453 headers for small block,does anyone know if they angle in?
Re: TTI headers on small block [Re: jst19600] #3208088
01/25/24 01:13 PM
01/25/24 01:13 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
No, they do not.
The collector runs parallel with the torsion bar.
Re: TTI headers on small block [Re: jst19600] #3208424
01/27/24 08:38 AM
01/27/24 08:38 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Having had both TTI’s and Dougs on A body small blocks, I much prefer the fit of the Dougs, and they make good power.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
