Re: Trailer tires [Re: SomeCarGuy] #3208102
01/25/24 01:52 PM
01/25/24 01:52 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Here's my twocents As other have said don't cheep out. I have an Enclosed (15,600lbs gross) that came with 225/85R15 E Good Year Marathons from the factory. Every 2 years a couple of them needed replacing due to belt failure. I switched to a 235/85R16 E Good Year Marathon and have not had a Belt failure since. Side wall deflection is typically the root cause for trailer tire failure. The E rated 16" has more belts and consequently a higher load rating and If I recall correctly they are (were) less expensive than the 15". My Big trailer (21600 Gross) has 235/85R16 Maxon 10ply (from the factory) and so far so good on wear and reliability. Point being more tire (load capacity) is cheaper in the long run.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Trailer tires [Re: W.I.N. Racing] #3208107
01/25/24 02:44 PM
01/25/24 02:44 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Load ratings and number of plys is all good, but don't forget . . . trailer tires also have SPEED ratings on them. Most of the lower price tires are "only" rated to 55 or 60mph max !!! . . . . If you are running down the interstate at 70mph, then make sure the tire can handle that speed.
Re: Trailer tires [Re: a12rag] #3208151
01/25/24 07:19 PM
01/25/24 07:19 PM
work
Thanks for the heads up up bow
Re: Trailer tires [Re: gtx6970] #3208183
01/25/24 09:31 PM
01/25/24 09:31 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
I have read that Air Stream Travel trailers are putting Michelin LT truck tires on new trailers. The Defender AT/2. Wonder how they would hold up on a car hauler?
America First!
Re: Trailer tires [Re: carnut68] #3208190
01/25/24 10:28 PM
01/25/24 10:28 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
LT tires are illegal on trailers in some states, but of course unless you are going through scales I doubt anyone would care. Now if you had an accident, that may be enough to not get paid from your insurance company... work
JB Rhinehart, Realist
A-Body's RULE!
Re: Trailer tires [Re: carnut68] #3208211
01/26/24 04:37 AM
01/26/24 04:37 AM
I looked for LT tires for my 1999 Pace Shadow that came with 215x75x15 inch tires and 6 lug 5000 Lb axles 4 or 5 years ago, none of the 15 inch LT tires had a higher load rating than the trailer tire had back then whiney scope
The way to get better rated trailer tires was to switch to 16 inch rims and tires shruggy
Re: Trailer tires [Re: Cab_Burge] #3208243
01/26/24 10:02 AM
01/26/24 10:02 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ll be going on season 5 on our Greenball Towmaster ACS “G” rated 16” trailer tires. That’s been pretty much unheard of for us in the desert. 100psi 4080 load range 75mph speed rating. I will add that once going to them I’ve removed them from the trailer from late May until September and store them inside to keep them out of the blazing sun.
Re: Trailer tires [Re: J_BODY] #3208268
01/26/24 11:36 AM
01/26/24 11:36 AM
Rhinotruck
Rhinotruck
What 16" 6-bolt rims are being used and where to buy them? All the 16" rims I see are 8-bolt... shruggy
A-Body's RULE!
Re: Trailer tires [Re: Cab_Burge] #3208281
01/26/24 01:07 PM
01/26/24 01:07 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Originally Posted by Cab_Burge
What size axles and how many lug bolts wheels does our trailer have on it. Is it enclosed or an open trailer?
5 lug , 15inch wheels , dual 3500 pd axles , 20 ft enclosed trailer
Re: Trailer tires [Re: topside] #3208296
01/26/24 01:58 PM
01/26/24 01:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Goodyear Endurance on all three of my trailers. One set is 8 years old and still hanging in there. And out here in the desert that's saying something.
Re: Trailer tires [Re: Rhinodart] #3208453
01/27/24 10:42 AM
01/27/24 10:42 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I think any 6 lug chevy truck wheel wit fit, that's what (15") I use for my spare.
16" here. https://www.etrailer.com/Trailer-Tires-and-Wheels/Dexstar/AM20757.html
Re: Trailer tires [Re: justinp61] #3208478
01/27/24 01:00 PM
01/27/24 01:00 PM
Rhinotruck
Rhinotruck
Thanks!
A-Body's RULE!
Re: Trailer tires [Re: Al_Alguire] #3209022
01/29/24 03:54 PM
01/29/24 03:54 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Good to hear the feedback. Probably will be my next set.
Re: Trailer tires [Re: Rhinodart] #3209027
01/29/24 04:01 PM
01/29/24 04:01 PM
My 34 Ft. travel trailer had them on it, with dexter brand 6000 lb. axles with 6 lug 16 inch rims and tires, sorry for not knowing the brand of the wheels whiney confused
Re: Trailer tires [Re: Cab_Burge] #3209227
01/30/24 02:58 PM
01/30/24 02:58 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I went with the newly designed HanKook Vantra E-rated tires(10Ply) ST225/75R15 for my 24' Bravo enclosed trailer - so far it tows much better with these tires than the cheap D-rated tires it came with from the factory - Next trailer will be 16" rims
Re: Trailer tires [Re: mopars4ever] #3209337
01/30/24 09:38 PM
01/30/24 09:38 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Goodyear Endurance trailer tire are the best I have been using them for a few years now I'm wearing them out with no blow outs before Endurance's 2 or 3 blow outs a year.
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
