315 60/15 M/T ET Streets on 68-70 Plymouth B body
#3207144
01/22/24 11:54 AM
01/22/24 11:54 AM
Posts: 10,049 MN
JERICOGTX
MN
Anyone running a 315 60/R15 rear tire on a 68-70 PLYMOUTH B body?
Thanks.
69 GTX
68 Road Runner
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body
[Re: JERICOGTX]
#3207184
01/22/24 01:44 PM
01/22/24 01:44 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
Won't fit without a mini-tub in a B-Body. I have them on my mini-tubbed E-Body and they fit nicely.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3207189
01/22/24 01:52 PM
01/22/24 01:52 PM
Posts: 10,049 MN
JERICOGTX
MN
Won't fit without a mini-tub in a B-Body. I have them on my mini-tubbed E-Body and they fit nicely. My car is mini tubbed. I'll be using a 12" wide wheel.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3207196
01/22/24 02:08 PM
01/22/24 02:08 PM
6PKRTSE
Motor City
Should fit nice if the back space is right or springs are moved inboard or ladder bar or 4 linked.
My Challenger is also on 12" wide wheels with 315 D.R.'s.
[Re: JERICOGTX]
#3207213
01/22/24 03:05 PM
01/22/24 03:05 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Width-wise they WILL fit with the proper wheel offset ... 15 x 10 with 5-1/2 BS. HOWEVER, that's a 30" tall tire ... ain't gonna fit without rubbing the front of the wheel openning. A 325/50r15 is a 28" tall tire and will fit. I have a 69 RR Current tire is a M/T 28 x 12.5 x 15LT on 15 x10 Welds with 5-1/2 BS. These tires are dimensionally the same as the 325/50r15 but are a bias ply as opposed to a radial. Worth mentioning is that they fit but are VERY close to the inner wheel well.
[Re: Stanton]
#3207228
01/22/24 03:44 PM
01/22/24 03:44 PM
Posts: 10,049 MN
JERICOGTX
MN
I've ran 31"x 10.5W's for many years on the car, with 12 inch rims. I'm switching the car over to a street car now, and want to run the radial for the street, for stability. Car will retain the ladder bars and coilovers.
69 GTX
68 Road Runner
[Re: markz528]
#3207364
01/22/24 11:41 PM
01/22/24 11:41 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
No idea why picture is sideways............
[Re: Stanton]
#3207365
01/22/24 11:43 PM
01/22/24 11:43 PM
markz528
Morrow, OH
Width-wise they WILL fit with the proper wheel offset ... 15 x 10 with 5-1/2 BS. HOWEVER, that's a 30" tall tire ... ain't gonna fit without rubbing the front of the wheel openning. . My quarter panel s trimmed in the front wheel well for that reason...........
[Re: Stanton]
#3207446
01/23/24 10:19 AM
01/23/24 10:19 AM
Posts: 10,049 MN
JERICOGTX
MN
What’s the point of the question when the tire currently on the car is bigger than the one you plan to use ?!?!?
I'm putting new AMD quarters on the car, and need to know if the front of the opening needs to be trimmed. Mine are trimmed now for the 31" tires, but doesn't mean much, when all that is changing.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3207478
01/23/24 12:13 PM
01/23/24 12:13 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
I'm putting new AMD quarters on the car, and need to know if the front of the opening needs to be trimmed. Mine are trimmed now for the 31" tires, but doesn't mean much, when all that is changing. A friend has 295-65/15 M/T on his 69 Sport Satellite. Pretty much the same diameter as the 315-60. They were too close to the front of the opening so I made aluminum spacers for the front spring mounts. I think they were 3/8" thick ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) but they could have been 1/2" thick. The tires have never rubbed.
[Re: GomangoCuda]
#3207509
01/23/24 01:26 PM
01/23/24 01:26 PM
Posts: 1,030 ohio
67mprfan
ohio
[ A friend has 295-65/15 M/T on his 69 Sport Satellite. Pretty much the same diameter as the 315-60. They were too close to the front of the opening so I made aluminum spacers for the front spring mounts. I think they were 3/8" thick ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) but they could have been 1/2" thick. The tires have never rubbed. [/quote] When I was in jegs, the 295 & 315 were side by side, the 295 was taller. Both are 30 inches tall but the 295 was closer to 31
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: JERICOGTX]
#3207578
01/23/24 05:03 PM
01/23/24 05:03 PM
markz528
Morrow, OH
I'm putting new AMD quarters on the car, and need to know if the front of the opening needs to be trimmed. Mine are trimmed now for the 31" tires, but doesn't mean much, when all that is changing. If you PM me your email I can send you close-ups of how much mine were trimmed.
[Re: topside]
#3207724
01/24/24 06:50 AM
01/24/24 06:50 AM
Posts: 10,049 MN
JERICOGTX
MN
My thinking on this, FWIW, is to pie-cut the forward flange area before painting - rather than pull the driveshaft out of the trans any amount. Unless of course the openings need to be stock size. I've done that on a Duster - flange ended up pretty much flush with the forward area of the wheelhouse. It took close examination by someone who knew the original dimensions to see the opening was modified. I picked up a good 2" of tire diameter room. I'm not opposed to pie cutting the the 1/4 to open up the wheelwell, but do not want to go as far as I did on the old 1/4 panels, as I want to reinstall the original wheeelwell moldings, and rocker panel moldings. I'm thinking the radial will not grow like the bias ply slicks, and it shouldn't be as much of a problem if it's tight. I want the wheelwell filled with tire.
69 GTX
68 Road Runner
[Re: markz528]
#3207725
01/24/24 06:50 AM
01/24/24 06:50 AM
Posts: 10,049 MN
JERICOGTX
MN
I'm putting new AMD quarters on the car, and need to know if the front of the opening needs to be trimmed. Mine are trimmed now for the 31" tires, but doesn't mean much, when all that is changing. If you PM me your email I can send you close-ups of how much mine were trimmed. Send them to gtxracing@msn.com. Thanks.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3207736
01/24/24 08:31 AM
01/24/24 08:31 AM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
The radials definitely don't grow and distort as much as the bias ply tires do - I have the 295/65's on mine and it's within about a pinky's width of clearance to the leading edge of the wheelwell trim and I've never had issues with it rubbing.
