315 60/15 M/T ET Streets on 68-70 Plymouth B body #3207144
01/22/24 11:54 AM
01/22/24 11:54 AM
MN
JERICOGTX Offline OP
MN
Anyone running a 315 60/R15 rear tire on a 68-70 PLYMOUTH B body?
Thanks.
69 GTX 68 Road Runner
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207184
01/22/24 01:44 PM
01/22/24 01:44 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Won't fit without a mini-tub in a B-Body.
I have them on my mini-tubbed E-Body and they fit nicely.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: 6PKRTSE] #3207189
01/22/24 01:52 PM
01/22/24 01:52 PM
MN
MN
My car is mini tubbed. I'll be using a 12" wide wheel.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207196
01/22/24 02:08 PM
01/22/24 02:08 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Should fit nice if the back space is right or springs are moved inboard or ladder bar or 4 linked.
My Challenger is also on 12" wide wheels with 315 D.R.'s.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207213
01/22/24 03:05 PM
01/22/24 03:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Width-wise they WILL fit with the proper wheel offset ... 15 x 10 with 5-1/2 BS. HOWEVER, that's a 30" tall tire ... ain't gonna fit without rubbing the front of the wheel openning. A 325/50r15 is a 28" tall tire and will fit. I have a 69 RR Current tire is a M/T 28 x 12.5 x 15LT on 15 x10 Welds with 5-1/2 BS. These tires are dimensionally the same as the 325/50r15 but are a bias ply as opposed to a radial. Worth mentioning is that they fit but are VERY close to the inner wheel well.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: Stanton] #3207228
01/22/24 03:44 PM
01/22/24 03:44 PM
MN
MN
I've ran 31"x 10.5W's for many years on the car, with 12 inch rims. I'm switching the car over to a street car now, and want to run the radial for the street, for stability. Car will retain the ladder bars and coilovers.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207349
01/22/24 10:46 PM
01/22/24 10:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A 31x10.5 is way larger than a 315/60x15. It'll fit easily.
Doug
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207363
01/22/24 11:40 PM
01/22/24 11:40 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Mine
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: markz528] #3207364
01/22/24 11:41 PM
01/22/24 11:41 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
No idea why picture is sideways............
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: Stanton] #3207365
01/22/24 11:43 PM
01/22/24 11:43 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by Stanton
Width-wise they WILL fit with the proper wheel offset ... 15 x 10 with 5-1/2 BS. HOWEVER, that's a 30" tall tire ... ain't gonna fit without rubbing the front of the wheel openning. .
My quarter panel s trimmed in the front wheel well for that reason...........
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: markz528] #3207366
01/22/24 11:44 PM
01/22/24 11:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What’s the point of the question when the tire currently on the car is bigger than the one you plan to use ?!?!?
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207436
01/23/24 10:03 AM
01/23/24 10:03 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Not yet, but I might.
Rich H.
Esse Quam Videri
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: Stanton] #3207446
01/23/24 10:19 AM
01/23/24 10:19 AM
MN
MN
I'm putting new AMD quarters on the car, and need to know if the front of the opening needs to be trimmed. Mine are trimmed now for the 31" tires, but doesn't mean much, when all that is changing.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207478
01/23/24 12:13 PM
01/23/24 12:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
A friend has 295-65/15 M/T on his 69 Sport Satellite. Pretty much the same diameter as the 315-60. They were too close to the front of the opening so I made aluminum spacers for the front spring mounts. I think they were 3/8" thick shruggy but they could have been 1/2" thick. The tires have never rubbed.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: GomangoCuda] #3207509
01/23/24 01:26 PM
01/23/24 01:26 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
A friend has 295-65/15 M/T on his 69 Sport Satellite. Pretty much the same diameter as the 315-60. They were too close to the front of the opening so I made aluminum spacers for the front spring mounts. I think they were 3/8" thick shruggy but they could have been 1/2" thick. The tires have never rubbed. [/quote]
When I was in jegs, the 295 & 315 were side by side, the 295 was taller. Both are 30 inches tall but the 295 was closer to 31
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207578
01/23/24 05:03 PM
01/23/24 05:03 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
If you PM me your email I can send you close-ups of how much mine were trimmed.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: markz528] #3207622
01/23/24 07:44 PM
01/23/24 07:44 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
My thinking on this, FWIW, is to pie-cut the forward flange area before painting - rather than pull the driveshaft out of the trans any amount.
Unless of course the openings need to be stock size.
I've done that on a Duster - flange ended up pretty much flush with the forward area of the wheelhouse.
It took close examination by someone who knew the original dimensions to see the opening was modified.
I picked up a good 2" of tire diameter room.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: topside] #3207724
01/24/24 06:50 AM
01/24/24 06:50 AM
MN
MN
I'm not opposed to pie cutting the the 1/4 to open up the wheelwell, but do not want to go as far as I did on the old 1/4 panels, as I want to reinstall the original wheeelwell moldings, and rocker panel moldings. I'm thinking the radial will not grow like the bias ply slicks, and it shouldn't be as much of a problem if it's tight. I want the wheelwell filled with tire.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: markz528] #3207725
01/24/24 06:50 AM
01/24/24 06:50 AM
MN
MN
Send them to gtxracing@msn.com. Thanks.
Re: 315 60/15 M/T ET Streets on 68-70 Plymouth B body [Re: JERICOGTX] #3207736
01/24/24 08:31 AM
01/24/24 08:31 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The radials definitely don't grow and distort as much as the bias ply tires do - I have the 295/65's on mine and it's within about a pinky's width of clearance to the leading edge of the wheelwell trim and I've never had issues with it rubbing.
