.010 under 440 main bearings?
#3207284
01/22/24 06:09 PM
01/22/24 06:09 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I had H series bearings, .010 under size, in my BMP block and need another set. I want a half grove, anybody have them?
Re: .010 under 440 main bearings?
[Re: HardcoreB]
#3207438
01/23/24 10:09 AM
01/23/24 10:09 AM
Posts: 9,867 MI, usa
dvw
MI, usa
What is differet with the HG series? I've always used MS2233HG Doug
[Re: dvw]
#3207442
01/23/24 10:12 AM
01/23/24 10:12 AM
Posts: 1,154 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3207452
01/23/24 11:08 AM
01/23/24 11:08 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I have used everything from Clevite HG, Sealed Power and as of late King bearings. I prefer King bearings these days, they offer more of a selection to get the proper clearances as needed and come coated for not much more than Clevites uncoated bearings. Obviously, coating cost more from Clevite. I have King bearings in my latest 440 with over 55,000 on it and 5 seasons on my Hemi and they still look like new.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: HardcoreB]
#3207475
01/23/24 11:57 AM
01/23/24 11:57 AM
gregsdart
I'm not sure the H series Clevite is the same as it was in the past. I'd look for other manufacturers and be open to some input from current experiences. Sean, exactly! I ordered sealed power, but don't really want a 3/4 grove, as a half grove provided the best results, according to one site. So i will fontinue to look around. Only the best when pushing things hard.
[Re: gregsdart]
#3207507
01/23/24 01:23 PM
01/23/24 01:23 PM
dvw
MI, usa
I'm not sure the H series Clevite is the same as it was in the past. I'd look for other manufacturers and be open to some input from current experiences. Sean, exactly! I ordered sealed power, but don't really want a 3/4 grove, as a half grove provided the best results, according to one site. So i will fontinue to look around. Only the best when pushing things hard. I've had zero issues with the 3/4 groove groove bearings. Never hurt a main in 12 years. Doug
[Re: dvw]
#3207574
01/23/24 04:49 PM
01/23/24 04:49 PM
gregsdart
[quote=HardcoreB]I'm not sure the H series Clevite is the same as it was in the past. I'd look for other manufacturers and be open to some input from current experiences. Sean, exactly! I ordered sealed power, but don't really want a 3/4 grove, as a half grove provided the best results, according to one site. So i will fontinue to look around. Only the best when pushing things hard. I've had zero issues with the 3/4 groove groove bearings. Never hurt a main in 12 years. Thanks Doug. As I rrecall, you also use a lighter oil than I do.
[Re: gregsdart]
#3207575
01/23/24 05:02 PM
01/23/24 05:02 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
Are you sure you don't want your rods and rod baring to have full time oiling, especially in a race motor above 5500 RPM I've used full groove main bearings in every motor I've built since the early 1070s. I now use the narrow full groove bearings on all my build, street, street and strip and race only motors. I like lots of bearing to crankshaft clearances also, .0025 + on the rods and .0030+ on the main bearings. I like and use high volume oil pumps with thin oil also, 5W20 WT or 10W30 Wt. 10 Lbs. of pressure per 1000 RPM with hot oil, IE 7500 RPM 75+Lbs oil pressure
[Re: gregsdart]
#3207685
01/24/24 12:07 AM
01/24/24 12:07 AM
Posts: 31,061 Oregon
AndyF
I'm not sure the H series Clevite is the same as it was in the past. I'd look for other manufacturers and be open to some input from current experiences. Sean, exactly! I ordered sealed power, but don't really want a 3/4 grove, as a half grove provided the best results, according to one site. So i will fontinue to look around. Only the best when pushing things hard. I'd run a 3/4 groove bearing if it was available. They were never available for the low deck stuff I was doing back in the day but they would be a good choice for an RB. The engine builder I work with prefers King bearings for Mopars these days but sometimes they are hard to find.
[Re: Cab_Burge]
#3207750
01/24/24 10:21 AM
01/24/24 10:21 AM
Posts: 2,521 PA
moparacer
PA
Are you sure you don't want your rods and rod baring to have full time oiling, especially in a race motor above 5500 RPM I've used full groove main bearings in every motor I've built since the early 1070s. I now use the narrow full groove bearings on all my build, street, street and strip and race only motors. I like lots of bearing to crankshaft clearances also, .0025 + on the rods and .0030+ on the main bearings. I like and use high volume oil pumps with thin oil also, 5W20 WT or 10W30 Wt. 10 Lbs. of pressure per 1000 RPM with hot oil, IE 7500 RPM 75+Lbs oil pressure Same here Cab.Full groove, No problems with bearings ever. I pretty much run the same setups as you do. Except I run a little heavier oil at those clearances. Even reused my current bearings a couple years ago when we got in a jam due to covid.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: AndyF]
#3207752
01/24/24 10:34 AM
01/24/24 10:34 AM
gregsdart
I'm not sure the H series Clevite is the same as it was in the past. I'd look for other manufacturers and be open to some input from current experiences. Sean, exactly! I ordered sealed power, but don't really want a 3/4 grove, as a half grove provided the best results, according to one site. So i will fontinue to look around. Only the best when pushing things hard. I'd run a 3/4 groove bearing if it was available. They were never available for the low deck stuff I was doing back in the day but they would be a good choice for an RB. The engine builder I work with prefers King bearings for Mopars these days but sometimes they are hard to find. Thanks all for the input. I ordered a set of Sealed Power 119m-10, sounds like they will do the job.
[Re: gregsdart]
#3207867
01/24/24 05:29 PM
01/24/24 05:29 PM
Cab_Burge
[quote=AndyF][quote=gregsdart][quote=H Thanks all for the input. I ordered a set of Sealed Power 119m-10, sounds like they will do the job. i use them to when I can get them There are other sets, both babbitt and tri metal, that work nicely also. Sorry I can't remember the brand and part #s off the top of my head now
